Question about Whirlpool Duet GHW9150P Front Load Washer
F 11 shows on the washer and the machine stops. in the manual it says "electrical problem" can you tell me exactly what electrical problem that is? thank you. Anna.
  • 2,382 Answers
Hi, to solve the F11 error, remove the top cover by removing the three 7mm screws on the back of the machine at the top. Slide the cover to the rear and lift off. The CCU board has 2 relays on it. They have white plastic covers. One is labeled K4 and I believe the other is K2. There are five legs on each relay soldering them to the circuit board. Remove the circuit board from the machine. It is the one you can see with the top off in the back of the machine. Unplug all the connectors. Unsolder the 2 relays...brand name Omron. With a jewelers screwdriver carefully remove the plastic cover on the K4 relay. Examine the contact points on the normally open contacts and I will guarantee they will look dull and burnt. They should be bright and shiny. You can burnish the contact points lightly and clean them with electrical contact cleaner. If you take off the cover of the 2nd relay you will see the contact points are nice and bright and shiny. Swap the 2 relays and resolder them on the circuit board. While you have the board out, take a pencil eraser and rub it on the contact points where all the connectors slide onto the board. Spray the electrical contact cleaner to wash any residue away. Carefully reinstall the circuit board and replace the top cover. Our machine has done dozens of loads since I did this with no more problems. I expect another failure at some point when the points deteriorate on the swapped relay. At that point I will try and find replacements for both relays. The K2 relay apparently has less voltage going thru the contacts and does not fail. If you feel real comfortable, you can check the "wiping" action of the points by manually operating the relay when you have it out. I adjusted mine to give a bit more wipe on both relays.
Posted on Oct 05, 2010
Hotpoint aqualtis washing machine model AQXXL 129 PM my doors not locking stopping in a cycle ,and water not draining , and lights flashing
find a dealer and get a manual for the washer it will have a trouble shooting section will tell exactly what is wrong
May 17, 2014 | Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Instruction Manual for Washing Machine
hi, try this site www.retrevo.com hope it helps
regards
shaun
Oct 26, 2011 | Haier XQG50-11 Front Load Washer / Dryer
When the water runs inside the washer always show the F1 and the machine stop.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Sep 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Engine light is on and fault code 11 is showing and wont turn over
Do a thorough check on all your electrical and wiring systems, as code "11" indicate an electrical wiring problem. To pinpoint the exact location need to check with a Yamaha Workshop manual book.
Mar 21, 2010 | 2003 Yamaha YZF-R1
The machine stops
The F11 error code is a communication failure between the 2 control boards. This includes both boards & the wiring harness as potential defective components. However, this is usually the main machine control board that needs replaced.
Dec 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F-11 keeps stopping the machine & need to know what to do
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Nov 29, 2009 | Kenmore Elite HE4 Electric Dryer
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
I have the kenmore 90 series top load electric washer. Model #110.92291100. I am trying to find out if it's a 3cubic or a 4cubic size. I am replacing it and I want the exact same size. It says Heavy Duty...
I couldn't find the exact size using the model number provided... i would bet that it's a 3.5 - 4 cu.ft. model... My suggestion is to get something other than a GE washing machine... Go with a Kenmore, Whirlpool or Maytag
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Duet washing machine
f-11 is a motor control unit error.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
