Question about Carrier Beverage-Air UR30GEFD Beverage Cooler
Fan in cooling compartment
I have a Beverage- Air refrigerator model ur30ged it is working keeping things cool but the fan in the cooling compartment is running constantly. I can turn the thermostat to the off position and it keeps running. Is this normal? Everything else seems to be working good.
    Scholar:
  • 81 Answers
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
Posted on Jun 07, 2009
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Beverage air won't keep cooling
Hi David, sorry about that, I just found your model number. I want to help you but I need a few things first. First when is is plugged in and on can you tell me if the compressor is running? You can find it near the coils in the back, you can touch it and it wont shock you but it could be very hot so be careful. If it is running can you see if the fan in the back beside it is running?
Dec 10, 2013 | Beverage-Air UCR48A Compact Refrigerator
I have a Beverage Air cooler (Model UR30G) where the fans seem to be running, but only warm air comes out...it's about 10 yrs old and is in great looking shape and would love to find a way to fix....any...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 26, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
Nov 17, 2009 | Beverage-Air MT27 Beverage Cooler...
Our model HRF08W frig never cooled properly (although
Yes, there is a fan that moves cold air from the freezer compartment to the refrigerator. If this does not turn, the refrigerator compartment will not receive adequate cooling.
If the fan is turning, you should be able to hear it. It is likely located behind an access door in the freezer compartment. This door is likely held in place with screws. Remove the screws, open the door, and see if the fan is turning. If not, you will need to replace the fan motor.
Oct 14, 2009 | Refrigerators
Refrigerator compartment not cooling properly.
Yes The circulating fan behind the rear freezer wall is waring out. The fan with labor and material cost is around $300.00.
Jul 11, 2009 | Refrigerators
Beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
Jun 09, 2009 | Carrier Beverage-Air UR30GEFD Beverage...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
Carrier Beverage-Air UR30GEFD Beverage Cooler Logo
489 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
