Question about Ashly GQX1502S Home Equalizer
Top eq 10k stays on clip ? - Ashly GQX1502S Home Equalizer
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 232 Answers
Bad fader..shorted amp circuit...
Posted on Sep 20, 2014
How can I connect this EQ on my mustang I don't have amplifier right now only the EQ
an eq is kind of like an amplifier anyway it boost the sound and tailors the sound to your taste. Your eq should have a wiring diagram on the bottom or top of the unit. Your factory radio should have a wiring diagram on top or bottom of it as well. So all you have to do is match left + to left + and right + to right + etc. It's really easier than you think. You just have to pay close attention to the diagrams.
Feb 03, 2015 | Audio Players & Recorders
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
IBENEZ BASS AMP P500H NO SOUND
I had a short at one of the electrolytic capacitors at the EQ board. Check the voltages!
Apr 11, 2014 | Ibanez P500H Promethean Bass Amplifier...
What size preamp equalizer do i need for a 2000 watt amplifier for car subwoofers?
There is nada wrong with your preamp and changing it will accomplish nothing. If your channels are allegedly clipping it is due to the fact that it is being over driven. A bad preamp could not over drive your amp!
Have to be careful with tone controls at high levels. Every 3db increase compels amp to double power at that frequency. So if you are blasting at 2000 watts and you boost a control by that amount, your amp will put out 4000 watts and clip. If plus 6db then it is 8000 watts!
Jun 19, 2017 | Hifonics Car Audio & Video
Sound Problem
Sounds like something's up with your EQ. From the main menu, go to Music>Music Options>Music EQ and try another setting or play around with Custom. Could also be volume. Go to main menu>Settings>Reset All (NOT FORMAT!!!) Recommend trying both in given order. Hope this helps.
Jan 06, 2010 | SanDisk Sansa Clip MP3 Player
My pv6 mixers red clip lights remain on
FIRST check that your power adapter is 16 VAC at 1 AMP and that it is the original unit.
The clip lights monitor levels at several points. If you cranked the EQ's for maximum, say bass, that MAY cause them to illuminate.
As a test, set all EQ's at mid point. Remove ALL input cables. Are the lights still on?
It is possible that you can have a ground loop that is putting signals in that causes clipping. Another source is if you have a microphone that may be FEEDBACKING at supersonic frequency that you can't hear... that is why we disconnect all the inputs as a test.
Finding schematics so one can repair these devices can be a problem. If ALL the clip lights ar on, then it is probably the reference level source for the clip level threshold... however finding a schematic would be necessary and while part cost would be probably under a dollar, the labor and time to find the schematic would be unknown.
Aug 18, 2009 | Peavey 32fx USB 32 Channel Mixer
Okui 3530 toner sensor error
turn off eq - open and remove the drum with the color cartridge in locked position still in place - on the drum on the cartridge lock side you will find a small (1/4 ") rectangular "window"...with the catridge in locked position the window should be open so you can see the sensor...when the cartridge is unlocked the window should be closed...so with the cartridge locked, using a tiny pointed object (paper clip), gently move the panel up or down to the open position (mine moved up)....replace the drum with cartridge...make sure it is set properly...close up everything and turn eq back on....you may have to do this two or three times to make sure the window stays open when the lock is engaged...but this is what the "tech"(salesman) did...good luck
Nov 10, 2008 | OKI C3530N Color MFP Printer
Setting low pass and bass eq
Hello, i have a hifonics brutus also, in the manual it states to set the eq at half way, so that there is no clipping or at least to prevent clipping , the eq will make the bass punchier, if you do go pass half way, i would recommend to readjust your gain settings, also check your head unit settings and make sure everything is flat, bass, mid bass etc. example i had my eq past half but i had my gain at mid way, it was hitting hard, then i tried turning the eq all the way down and the turning up the gain and the bass was smoother so it depends where you set it, and what settings you have on your head unit tone control (bass, treble etc)
May 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
TV Capacitors
Get a 10K resistor, use an alligator clip to connect one side of the resistor to the ground of the TV (note, if you are working in the primary circuit of a switching power supply, do not use chassis ground, instead connect the alligator clip to the negitive side of the capacitor).
Use a good pair of insolated pliers to hold the body of the resistor and touch the free end of the resistor to the positive side of the capacitor.
Because of the 10K resistor it may take a minute to fully discharge. Heep holding it for at least a minute.
If you have a Voltage meter you can use it to verify the discharged state of the capacitor. (note you can get a multimeter for as little as $10 if you look around).
Apr 02, 2008 | Panasonic PV-C2010 20 in. TV/VCR Combo
Wire diagram for installation and where can i get the plastic inserts for the buttons
i just got the wiring for the sony xe-mk90II eq, heres a picture :
top right is the ground , bottom right is constant power, blue is the remote turn on. if you have a old wire harness around you can pull out the blue ,yellow, and black wires with the metal clip on and make than fit right where the wires should go. but make sure u rap the metal clips with electrical tape so the wires dont touch or you will fry it.
Feb 22, 2008 | Sony XE-90MKII 9-Band Car Equalizer
Ashly GQX1502S Home Equalizer Logo
53 people viewed this question
Top Ashly Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ashly Audio Player and Recorder Expert? Answer questions, earn points and help others
