I can't find the manual tray for my Brother MFC8480 DN printer. Where is it?
    Brigadier General:
  • 7,191 Answers
You can download and print the instruction manual from Brother website by clicking this link
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Thanks for using FixYa.
Posted on Oct 05, 2010
BROTHERS HL6050 DN RESET PAPER TRAY
Go To Below official Brother Printer Page For Your problem, How do clear the message No Paper from the display Brother Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Mar 26, 2014 | Brother HL-6050DN Laser Printer
How to replace tray 1 rollers
sir you can download service manual xerox 3600 in this link
http://www.itechmv.com/wp-content/uploads/2014/02/phaser3600.pdf
hope that it will help you
Sep 14, 2012 | Xerox Phaser 3600DN Laser Printer -...
What does it mean when your brother printer 8480 DN says load MP Tray?
That means that you have selected the manual feed tray in your computer as the destination. Either put a piece of paper in the pull-down slot or change the destination in your print dialogue box
May 13, 2011 | Office Equipment & Supplies
Printer makes a horrible sound when trying to print also the blue button on the right side making a loud clicking noise. the paper won't feed.8860 dn
I have had the exact same problem. The problem is in the tray. It won't raise the paper properly despite how much paper you have in it. Make sure that all of the springs are there, and that the plastic sensors are correct.
I've found it useful to just buy another tray. You can find it as low as $30-35.
It's a very typical mechanical problem, but most likely resolved by changing the tray.
Apr 01, 2011 | Brother MFC-8860DN Printer
I am having a problem with the paper tray for Brother MFC 8860 dn printer - The paper tray clicks when it is printing a page and then says there is no paper in the paper tray or that a page is jammed -...
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play. If the rear guide is tight, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, but will see calibration marks for the paper size you are using. Unlock the read paper guide n the tray, squeeze the release and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Oct 13, 2010 | Brother MFC-8860DN Printer
How do I print a #10 envelope on the Brother 8480 DN
You need to use the manual feed which is located above the paper tray.
Dec 31, 2009 | Brother MFC-9840CDW Laser Printer
NEED THE MANUAL. CAN'T FIND IT AND CD IS CORRUPT.
here is the User Guide:
Brother MFC8480 Manual
You can also go to http://www.brother-usa.com/support/ and select Multi-Function Center from the drop-down menu and then your model number from the next drop-down menu. Several links will be displayed for manuals, drivers, etc.
Thanks for using Fixya.
Oct 15, 2009 | Brother MFC-8480DN All-In-One Laser...
How to reset the drum counter on a brother printer HL5270 DN
There should be a way to reset the drum setting. Call Brother they will help you are look in your manual.
May 21, 2009 | Brother HL-5270DN Laser Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
Brother 5250DN printer noise
Check my solution here:
http://www.fixya.com/support/t641678-paper_tray_noise
Here's a solution for you with Brother HL 5250 D/DN/DNT
Change the paper setting tab in the tray to make sure you have a small gap between the top part of the paper and the bottom part.
so if this is the old settings : |paper| --> you want to make it: | paper| so you can have slide the paper back and forth.
DON'T adjust the setting to the next paper size because the roller wont catch the paper if it slide too far.
Good luck to all.
Nov 02, 2007 | Brother HL 5250DN Laser Printer
29 people viewed this question
jasbo
jasbo
