Question about Microwave Ovens
Fan and Light out on GE JVM 1650
I saw your solution for another on the GE JVM 1650. I forgot to unplug the microwave and during a bulb replacement it exploded in my hand. Now the fan and lights do not work. Do you have the replacement controller part on stock? I would be interested in purchasing it.
My e-mail is gblack100@yahoo.com
  • Greg May 30, 2008
    Excellent! Thank you! I will send you the board for repair. On average, how long does a repair of this take?
  • Microwave Ovens Master
  • 9,011 Answers
We actually repair these for customers nationwide for only $39.95 (details here).
If you'd prefer to get a new board, they run $106.94 plus shipping, and you can order one here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 28, 2008
  • William Miller
    William Miller May 30, 2008
    I answered this by e-mail to, but it's usually about a week door to door.
    Here's another set of tips for others, too:
    REMOVING BROKEN BULBS, LAMPS, SOCKETS, BASES
    First, be sure the microwave is unplugged.
    This is pretty common and can be a pain. It's often tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
    You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
    You may need to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
    Another trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
    I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
    Hope that helps!
I have a GE JVM 1870 over the range microwave with the active vent. The interior light is out which is a simply fix. How to I get to it?
follow this steps and fix it. God bless you
  1. Light bulb If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control board If your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Dec 09, 2013 | Microwave Ovens
We have the same F3 problem with our rangetop microwave. ..GE JVM 1650. We have a replacement keypad that a repairman ordered 2 years ago but did not need. How do you remove the old keypad and install...
Hi, I have a jvm1631 modle that looks like yours,on mine you need to remove the grill on top and then you should have a screw above clock,remove screw and lift up and the whole assemby will pop off.Then you will see tabs all around edge that you psuh in to remove plastic cover then you can unplug all wire harnesses and replace keypad. Just remember to unplug M/W first.Hope this helps.
Mar 05, 2011 | GE JVM1650 1000 Watts Microwave Oven
I have a JVM-1650-ch01 space saver oven hood and the oven light will not turn on. I've replaced the bulbs and the read out says that the light is on but the loght will not turn on by pressing the...
Sorry to read about your problem, I hope this helps you out.
The main control board controls the lite with a relay,, the relay is defective or you may have a broken wire
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM 1650 Microwave Night Light does not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
In your case, it may just be a shorted dimming diode, a black diode usually located between the light relay and the connector.
(Not to be mistaken for the tinier red-bodied diode on the other side of the relay that protects the relay coil).
If it is shorted, you will have bright lights in both the bright and dim settings.
In case you or someone you know has the tools and experience to desolder and solder small components, the replacement rectifier diode is not critical and can be any of these:
1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, NTE116, or NTE125 some of which are available form Radio Shack.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Feb 13, 2009 | GE JVM1650 1000 Watts Microwave Oven
Fan and surface light of microwave GE out of order
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
William E. Miller
prototech@usa.net
Jan 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker XL Microwave Oven JVM 1650/1651
the microwave is running even though your not pressing any buttons? it would be a control board problem,. could be main relay contacts welded together.
Feb 19, 2008 | Microwave Ovens
Ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Jan 22, 2008 | GE JVM1650 1000 Watts Microwave Oven
Light Bulb Replacement On JVM 1860SF001
You can find an exploded view diagram by entering your model number (without the space) here: http://www3.sears.com/ That diagram may help.
Mar 23, 2007 | GE JVM1860 Microwave Oven
Microwave Ovens Logo
112 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
