Question about Canon PowerShot A630 Digital Camera
How do you apply date stamp when taking photos?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Posted on Nov 25, 2012
  • kakima Nov 25, 2012
informatica
  • 1114 Answers
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=14901 From page 37 of the manual it looks like you can only select the time stamp in "postcard" mode. Also the date & time need to be set in the camera first. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 18, 2007
  • 203 Answers
SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
Posted on Jun 02, 2008
dlundmark
  • 797 Answers
Set the resolution to PostageCard (1600x1200).
Many of these cameras have only ONE RESOLUTION setting which allows you to have a date/ date and time stamp on the file, which will print on the viewed or printed photo.
How to do it:
Turn the camera on M mode.
Use the func. set.
go down the menu to the resolution settings. (on the bottom of menu).
Pick only the postagecard (1600x1200) setting.
I also was like you, and had an awful time with a camera I was fixing. I then looked it up on the Net and found an online user manual for the Canon SD 500, which should be basically the same.
Posted on Jul 19, 2008
old marine
  • 2014 Answers
SOURCE: date stamp on photos for Canon SD100 IS
I believe you are referring to the PowerShot SX100 IS, as there is no SD100 IS. And yes, it does have the date stamp option while the image size is set to the postcard mode.
Posted on Jan 05, 2009
  • 18 Answers
SOURCE: Remove date/time stamp from photos
go to menu at shooting position. scrooll down to date menu and follow the succeding instructions.
Posted on Sep 23, 2009
Www kodak com go support
If you had the camera set to automatically stamp the date on the photos then the date is just as much a part of the photo as the subject.
You can use a photo editing program to try to mask over them. It's same process you'd use to get rid of an unwanted person or object in the photo.
If you don't want the date stamped on future photos, set your camera to not stamp them. I'd like to tell you how to do that, but since you didn't specify the model of your Kodak camera I'm afraid I can't do that.
Dec 17, 2013 | Cameras
Tip
Lumix DMC-TZ5 - Adding Time and Date stamp to photos
  • Make sure you have set the date and time correctly on your camera.
  • View the picture you want to Time stamp, by changing left hand slider to green icon.
  • Press the circular 'Menu/Set' button
  • Press down arrow to get to playback mode in the onscreen menu.
  • Press right arrow to access this menu.
  • Press down arrow until 'text stamp' is highlighted.
  • Press right arrow to select.
  • Choose whether to apply stamp to single or multiple photos
  • Press 'Menu/set' to select photo to stamp.
  • Choose which stamps to add. Date, time, age etc..
  • Press 'Menu/set' again and select the 'Yes' box.
The only problem with this is that it will re-size your photos to about 3m, which can make them grainier if you took them at a higher resolution. Unfortunately there is no other way to time stamp your photos on this camera.
on Feb 26, 2010 | Panasonic Lumix DMC-TZ50 Digital Camera
I have a Panasonic Lumix DMC-FX520 and the date stamp wont appear on printed photos. The date shows when I take the photo,how do I get the datestamp to show up afterwards
Normally in the menu settings the options are entered so as to stamp the date in. So open menu settings and check on clock and date settings. check for links to date stamping in the menu and activate.
Sep 24, 2010 | Cameras
I want to take the date and time off already taken pictures so I can print the pictures without the date and time showing.
For already taken photos, you would need photo editing software to remove the date/time stamp. With such software you could either crop the photo to remove it, or apply more labor intensive technques such as cloning to cover it. One good, free, and easy to use photo editing software is Irfanview (www.irfanview.com). With this software you should be able to crop already taken photos to remove the stamp.
Nov 10, 2009 | Cameras
Show/print date stamp on my photos
In order to imprint the date stamp on photos, the photo size (L, M1, M2, M3, S, Postcard) must be set to Postcard, and in the recording menu the "Date Stamp" option must be set to Date or Date & Time.
Oct 20, 2009 | Canon IXY 1000 Digital Camera
Sep 23, 2009 | Canon Powershot A1000IS 10MP Digital...
Time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Feb 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
TZ 5 not TZ50! Date stamp.
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or, view picture you want date & time stamped. Press the circular 'Menu/Set' button. Press down arrow to playback mode. Press right arrow on 'text stamp'. Choose whether to apply stamp to single or multiple photos. Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Aug 30, 2008 | Panasonic Lumix DMC-TZ50 Digital Camera
Date does not displayed on printed image
in the camera setup menu you have to have the time and date stamp turned on before you take the picture. Once you turn this feature on all of your photo will have time and date stamps. unless you turn it off.hope this helps
May 19, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Nikon D80 date imprint/stamp
Dear Bryx,
Unfortunately there is no way to have the nikon d80 print the date directly on the images, but the information is stored to the EXIF data on every image.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 06, 2008 | Cameras
Canon PowerShot A630 Digital Camera Logo
16 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
