Question about GE WBVH6240F Front Load Washer
GE front load washer
Problems with drain and spin
    Genius:
  • 1,028 Answers
Remove bottom cover ..remove as much water as possible from inside tub remove cleaning port on front of pump by turning counter clockwise..rmove all money lint screws nails be sure to ck into pump itself
Posted on May 29, 2008
dauphine
  • 207 Answers
SOURCE: front load washer
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Posted on Apr 20, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
It could be anything from a bad belt to a bad clutch to a bad tranny. In my opinion this washer is not worth repairing.
Posted on Jan 09, 2009
SOURCE: ge front load washer does not spin or drain
Unscrew the botom front panel,behind that you will see a lint trap,with the power off,and unplugged,place lot of towels on floor at this trap,unscrew slowly,as water will exscape,trap will pull out with plug,clean trap,,,,,,,,,,,,,,,,,,,,,,,trap is about 1.5 inches round,it located at bottom right side of my machine,,,,,,,,,good luck
Posted on Apr 11, 2009
kapishtech
  • 2272 Answers
SOURCE: GE front load washer is not draining after spin cycle
The draining is controlled by drain pump in the washing machine. If the drain pump is clogged or got loose then water will not drain properly and this problems will occur.Remove the drain pump and drain hoses. First thing you can do is take the drain hose and blow into it and check if its getting blocked.If the air is passing through the hoses then loosen the hoses to the pump. You might want to get some pinch off pliers to save water from going ever where or a shop vac to **** out the tub. If the pump is getting warm current is flowing to it and propeller is jammed more than likely. The front should have a couple of 1/4 screws at the corners on the front should pop after removing them. If you require parts then you can buy them from www.repairclinic.com Thanks. you can rate this solution and show your appreciation.
Posted on May 17, 2010
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
GE frontload washer doesn't spin
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
Ge washer won't let water spin out
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
GE Spacemaker Washer Tan does not spin or drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 20, 2011 | GE Spacemaker Washer and Dryer Electric...
Ge washer won't spin and drain
heatman101
Mar 30, 2011 | GE Washing Machines
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Our ge washer will not drain water out before it goes to spin cycle
heatman101
Jan 23, 2011 | GE Profile WPSR3120WWW
My top load ge washer wont spin out?
heatman101
Sep 23, 2010 | GE Washing Machines
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
GE WBVH6240F Front Load Washer Logo
144 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
