Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 43UUWX10B After replacing my IC's to no avail, I think I now need to replace some resistors. I am in need of a parts list or schematic or service manual in order to determine what the part numbers are related to the boards labeling. (ie rk46=AT03195s) Without me purchasing a manual can you help? thanks in advance, Daniel
  • Daniel Sorrels May 28, 2008
    without a schematic which resistors are those?
  • Daniel Sorrels Jun 16, 2008
    Thanks!!! I actually went and replaced ALL 13 of the resistors; figureed why not at ~1.50 eacha small price to not have to pull the board again soon.
    Reinstalled the board last night, and GOOD AS NEW!!
    Thanks for the help, nothing like the feeling of accomplishment and saving $1000's.
    Thank you again,
    D
  • 121 Answers
The resistors often burn out on that set when the convergence ic's go. The 3.3ohm 1/2watt metal film resistors those are usually the ones that burn out when the ic's go. you have to unsolder one side and lift the leg up out of circuit to check with a ohms meter. You can not check them in circuit make sure you lift a leg up to check or you will not get a correct reading
Posted on May 28, 2008
  • dawn garrett
    dawn garrett May 28, 2008
    the ones closest to your convergence ic's
How do you fix the color to a model 43fdx11b hitachi
Hello!you mean: colors out of convergence? nothing you can do about that, unless you replace 2 convergence amplifiers I.C. chips, plus all those burned 1 watt low ohms resistors with exact values, which only could be obtained via service manual or schematics. After resistor is burned, there is no way to read color code properly, due to partial evaporation of pigments. this is a "pro" job. If you try or tried, already to converge those "stubborn" crosses, there is more to do, even after you removed and replaced two 20 pin I.C. chips, soldered dead into sweep module, plus located and replaced resistors with precise values, you need to get your settings back to normal, by going into "factory service mode' or, at least into "convergence alignment" menu and fight with those crosses!Don't forget the white "****"! Otherwise, you will be re-servicing your set all over after 30 days of usage.good luck,Alex.
Feb 01, 2012 | Hitachi Televison & Video
BLOWN RESISTORS
you can download your schematic that will tell you resistor values and the rest of the circuits and IC indentifications as well as test procedures and more , this is a ten part zip that can be opened with winzip and read with adobe just click here http://www.eserviceinfo.com/downloadsm/12926/Hitachi_50FX30B.html
then to order resistors you can get them here http://www.nteinc.com/
or look for an electronic parts supply store around you , but alot of the time they too have to order the parts, ecspecially certain valued resistors or other special valued parts
if you need more help just ask !
Dec 11, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi projection tv
I would change both ICs STK392-110 and also the 3.3ohm 1 watt resistors and the 1.8 ohm 1 watt you would need 2 of each resistor. Then your convergence would be new again. You can get replacement ICs and resistors at the following link with free shipping and free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 01, 2008 | Televison & Video
Need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Mar 24, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 53uwx10b
I believe you can order the convergence board replacement for $299 from Part Store, here's a link to it for my 61" Hitachi, which should use the same board:
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/61SWX12B/Hitachi+Ltd/Hitachi/CS00452R/New.aspx
They offer a 30 day hassle-free return policy, so if for some reason it wouldn't work for you or isn't the right part, all you'd be out is the return shipping, as the initial shipping is free.
I'm in the process of having my board fixed w/the IC/resistor kit and hopefully I don't need a whole new board.  We'll see, but give this a shot, I don't see how you can lose...  -TD
Mar 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 43fdx11b rear proj tv
you can check at vancebaldwin.com or ctechnicians.com
Jan 04, 2008 | Televison & Video
PT-51HX40b BP819
Only use the same part number when replacing convergence amps, or you will need to replace all of the power resistors with recommended values for the convergence amps subsituted.
Dec 08, 2007 | Panasonic PT-51HX40 51" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Convergence circut
Usually there are 2 convergence IC's, labeled STK392-110. Each IC has 3 channes. Each color needs to be corrected 2 ways, vertically and horizontally, so 6 channels are needed. usually one IC does red, red and haf of green while the other IC does the other half of green, blue and blue. If the red colors are off, change the IC closest to the red jack. If the blue is off, change the IC closest to the blue jack. If the green is out, you have a 50/50 shot at replacing the correct IC. It is recommended to use the STK392-150 when replacing the IC's so it might not be a bad idea to go ahead and replace both with the newer numbers.
Apr 11, 2007 | Hitachi 46UX24B/25K 46" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
