Question about Casio Exilim EXZ75 Digital Camera
Lens wont close!
I think my camera is sort of broken. it turns on but it only lets me see my pictures. i cant take no pictures. and my lens is stuck. it doesnt go back in when i turn it off...please help...what do i do?...
  • 477 Answers
Goto www.digitalcamrepair.com for help their is a self diagnosis page.
Posted on May 29, 2008
My ex Z1000 wont take pictures. i turn the camera on the lens goes in and out some times it looks like its going to let me take a picture and then the lens closes back into the camera and the screen goes...
your camera problem has the problem chance. Fisrt you should try with full charge battery. sometime weak battery cause also. Second main pcb does not resetting every time after taking picture. I hope you luck! Would you give more detail problem...
May 21, 2011 | Cameras
Screen black, i think it's a lens problem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Mar 29, 2011 | Canon PowerShot A470 Digital Camera
Hello i have a problem with my canon powershot A1000Is digital camera. When i open the cam it only shows black screen and when i`m trying to take a picture is also black even if i check it on the computer...
Nov 20, 2010 | Canon Powershot A1000IS Digital Camera
When I turn my camera on I do not get any type of image on the fold out screen and I also just get a black screen with all the options I have chosen but I cant seem to see"through" the lens
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 21, 2010 | Canon PowerShot S2 IS Digital Camera
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Lens is stuck
Hello Gruntny, in order to repair this Camera you will have to replace the OPTICS UNIT (ED13A). Please contact your nearest Sony Service. Best regards, Arpad
Dec 21, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
Canon powershot a510
Try this test. While turning camera off apply light pressure to the lens tube to see if there is a point where the gear engages to close the lens fully. This fault indicates broken gear teeth on the outside of the largest diameter barrel. Scrap the lens or use it for parts. A broken gear in the motor gear box will not respond to this test whatsoever. A lens that doesn't fully close, sticks up about a quarter inch and freezes on the Canon logo on power up inidicates the focus mechanism has not fully closed--perhaps a software glitch. The repair involves desoldering plastic ribbon connections and removal of the back panel to gain access to the focusing screw type motor armature to reset the small internal lens so it is flush with the back cover. This lens prevents the lens from completely closing. Reassemble and start taking pictures again.
Mar 21, 2006 | Canon PowerShot A510 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
62 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
