Question about Samsung HL-P5063W 50" Rear Projection HDTV
I have a Samsung DLP Model HL P5063W which has gotten increasingly loud, due to the cooling fan located directly behind the projection light. I took the light and the fuse panel away from the fan cleaned it very well and put it back together. Didn't fix the problem, so I assume I have to replace the fan. I need a part number and instructions on how to get the old fan out. I removed the 2 screws located in the front of the fan, but still could not move the fan shroud. Please advise, thanx in advance for your help.
  • 85 Answers
Hi there.not sure on the shroud removal bit,but a good oiling of the fan bearings should fix the noise issue.its a common grumble with computers and suchlike.avoid wd40,it only lasts so long.engine oil is as good as any to use! hope the info is of some use! regards, steve
Posted on Oct 05, 2010
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Samsung hl-p55063w TV MAKES A BUZZING NOISE WHEN I TURN IT ON COULD THIS BE THE COLOR WHEEL? WHERE IS IT LOCATED .
Color Wheel BP96-00674A Located right behind Lamp Pull Lamp out use a flace Light and you can see Color Wheel.
Encompass Parts Distribution has Free Service Manual that you can print out online for this Model. 1-800-638-3328
Sep 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50" DLP No picture and very deep & lound vibrating sound. Red lights flashing,Sand By Temp. And Green lights flash Lamp.
Loud sound you are hearing is coming from your color wheel and has your Lamp ever been replaced? this set has 3 Fans they all must be running for set to operate correctly! Encompass Parts has Boards and Color Wheel But for Lamps Mats has them for 99.00 1-800-628-1118 and EC Parts 1-800-638-3328
Jan 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W makes a whining sound and then goes off
The most common failure in the DLP that makes a whining sound would be the color wheel. They cost about $135 + labor because I wouldn't advise changing it by yourself.
Aug 02, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5063W DLP rear projection LCD red
Make sure that, obviously it's plugged in at both ends properly, but also that none of the pins are bent or broken.
Jul 23, 2009 | Televison & Video
How to change the color wheel of Samsung HL-P5063W
Look on Youtube for samsung color wheel. you should find your answers there...
Jul 18, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
237 people viewed this question
Jerry Greenberg
Jerry Greenberg
