Question about Bosch Indoor Gas Tankless Water Heater 1000P-LP
Bonjour j'ai un probleme sur un chauffe eau w135 avec allumuge par batterie l'orsque j'ouvre l'eau chaude la veilleuse s'allume les etincelles ce fond pour l'allumage de la flame mais le chauffe eau ne s'allume pas j'ai change la menbrane sans resultat pouver vous m'aide pour la panne merci
Bosch W135 water heater Not igniting, no clicking sound. Replaced batteries and still not lighting
i think you need to check the battery holder is good
and your getting the right supply to the internal ignitor board
if it uses 2 batteries then check there connections are metal
and not gone green or other issue with oxides
and the contact and supply isnt so good to the ignitor
and its not working i assume the ignitors board isnt being supplied
or the switching to energise the spark isnt working
or the ignitor board has failed
you can also attach images from a camera
use macro mode and natrual light
or non macro mode
pics are good
more info and some checks
Jun 04, 2015 | Water Heaters
Bosch w135 keeps on igniting
call Bosh ------------They can tell you exactly
Mar 13, 2014 | Bosch Water Heaters
1&1/2" recirc.pump ...
If there is power to it the entire time, then it is probably overheating
Dec 07, 2013 | Laing Thermotech Laing E1 ecocirc...
My 2007 Fleetwod ##0 FKDS TT has no hot water delivery, (cold is Fine) No water comes from any faucet (3), or shower(2). When hot water is tried a short squirt of water (Les than 1/2 sec ond) comes out and...
Check for faulty (broken/apart inside) and replace check valve on hot side of tank (top line) between line connection and tank. Stem, spring etc, of new one goes in facing into tank.
Jul 18, 2010 | RTO Atwood Water Heater - 6 Gal LP
Bosch Indoor Gas Tankless Water Heater 1000P-LP  Logo
126 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
