Question about Philips GoGear Flash MP3 Player
When i connect my philips go gear ipod to pc when some error shown that is 'wpd systemfile volume driver' pls tell me what i do
  • 10,421 Answers
Wpd enhanced storage password driver
Try re-installing the driver for this object. HP will have support drivers for this. John
Apr 09, 2012 | HP Computers & Internet
I downloaded files on my 8gb philips go gear SA52xx product connecting it to a pc and when i unplug the USB connection of my device after everything it has since then frozen and refusing to work even...
Hi leefordnarte,
You can find a lot of valuable resources on the Philips Support Site...I am not sure which specific model you have, but the Product Support Page for the SA5285/37 can be found here:
http://ow.ly/5XLe9
For the issue you described, I would attempt a Repair/Recovery - this process will restore your player to factory settings, as well as update the firmware in the process.
Try the Philips Device Manager software (found on the support site www.philips.com/support if you do not have your original software disc):
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
Hope this helps - if so, let me know by rating this solution. If you have any additional questions or need assistance, you can reach Consumer Care at 1-888-744-5477.
Aug 08, 2011 | Philips Audio Players & Recorders
Philips Ipod GoGear 1 GB cannot open.
my ipod cant play.. it says error report as "player problem" pls send rectify method.. my mail id is praka.nm@gmail.com
Sep 15, 2009 | Philips GoGear HDD6330 MP3 Player
My player displays a message
Connect player to pc and power, restart player while holding the volume + key, as soon as the player shuts off, press and hold the volume - key, your device manager will pop up and tell you the player needs repair, let it do so.
Jul 18, 2009 | Philips GoGear HDD6330 MP3 Player
I have philips go gear 1gb ipod. ...the moment i
You have to go to Philips website and download the Philips Device Manager for your model. Once you have installed it, run the Repair function.
-Tha Mp3 Doctor
Feb 24, 2009 | Philips GoGear SA178 MP3 Player
Philips GoGear SA60XX
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 26, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips go gear
Make sure you run the installation CD, or grab the software from the Philips website - this device will not work properly if Philips Device Plug-In is not installed. Does Windows Media Player 10 recognize the GoGear? If so, then the absence of a drive letter will not be a huge problem. If not, restart the computer and try one more time. A word to the wise - running this GoGear on a PC running Windows Media Player 11 will cause irreversible damage to the player. If you have Windows Media Player 11, rollback to WMP 10 - instructions are on the Philips and Microsoft websites.
If all else fails, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Jun 10, 2008 | Philips GoGear HDD1830 MP3 Player
No device connected
Try installing the newest version fo the software from the Philips website first.
www.usasupport.philips.com
Enter your model number
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "software and drivers"
If that fails:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Feb 07, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear Flash MP3 Player Logo
101 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
