Question about CorelDraw 9 Office Edition (   90oeengo)
Need to change from spainish to english
I have CorelDRAW 9 with all the extras. The program I bought in 2001,
I had a new hard drive installed and reloaded all the programs back on.
The CorelDraw 9 program is in spainish. I am unable to read it nor change it to english .. I would be very greatfrul if any one could help me.
Tu saves que me quieres
Posted on Jul 29, 2008
    Guru:
  • 859 Answers
You should uninstall the program and when you reinstall the program don't miss the part where you choose your language.
Regards,
Worldvet
Posted on May 28, 2008
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Nov 12, 2014 | Corel DRAW Graphics Suite X5
My pc keeps changing to spainish...have taken it to pc shop they fix it i get home ten mins later in spainish again
Remove all the languages you don't use from the system, and leave only the english one.
Aug 12, 2014 | Cars & Trucks
Can not change chrome to english from spainish
You can change the language settings in the Chrome preferences.
For step-by-step instructions you can check out the Google Chrome Support website: https://support.google.com/chrome/answer/95416?hl=en
Hope that helps!
Dec 11, 2013 | Google Chrome
My adobe reader 9 is another language I can't understand or read and I want it back to english. How do I change it back
try uninstalling and then installing it again...
to uninstall go to my computer and at the top it will say uninstall programs.
to install go to http://get.adobe.com/reader/
May 07, 2012 | HP Compaq 6720s Laptop
I bought the verbatim acclaim portable hard drive (turbo usb 2.0) today. It installed automatically in French... no choice of English (I want english). I did the installation and it says it is succesfull....
if your pc is in french then the hard drive install program will auto detect this and install the software in the default language , you will need to look for the english setup installer on the hard drive and install it manually. you will also need to right click on the file and click run as administrator then you wont receive the requested operation requires elevation error
If you found this info useful please vote for me
Mar 26, 2011 | Computers & Internet
I have downloaded tubular brushes for the artistic media tool of corel draw..but i have no clue how to install them.. pls assist me regarding this..n also if other accessories r available for corel..pls...
Unzip the files to
X:\Program Files\Corel\Graphics##\Draw\CustomMediaStrokes where X is the drive where CorelDRAW was installed and ## is your version of CorelDRAW. You'll need to restart your computer before the new brushes will be available from the Artistic Media Brushes drop-down list in the property bar. (CorelDRAW 9 or higher is required.)
Feb 27, 2011 | Computers & Internet
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
Compaq presario 700
Greetings,
My name is mark and I will be happy to assist you. Here are the steps to change the languages on your computer.
1.go to start then click on control panel.
2. go to languages change the display and desktop to the language you wish.
3. you do not change the "regional settings"
I hope this helps. If you need further assistance let me know.
Be mucho blessed,
Mark
Jul 02, 2008 | Compaq Presario 700 470024-192 Notebook
Thank you for your response
Hello, I am out of town today and will respond to you upon my return.
Regards,
Worldvet
May 29, 2008 | CorelDraw 9 Office Edition (  ...
CorelDraw 9 Office Edition (   90oeengo) Logo
250 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
