Question about Zanussi TC7102W Electric Dryer
Dryer is rotating but there is no heating - Zanussi TC7102W Electric Dryer
  • Zanussi Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 05, 2010
Dryer heats but won't rotate
The belt is broken or the motor is locked up,most likley the belt.
May 11, 2012 | Maytag Dryers
My dryer still rotates but it does not blow hot air and it contineously rotates.the only way it will stop is if Iopen the door
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 13, 2010 | Estate TEDX640JQ Electric Dryer
Dryer does not heat. It does rotate. Any ideas?
The heating is either a blown fuse or element and the rotating is the belt that has come off or broken or worts case the motor has packed up
Dec 28, 2009 | Whirlpool LEQ9858P Electric Dryer
Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer heats but the drum doesn't rotate
There is usually a large belt that goes around the drum to turn it ...it is either fallen off the motor pulley , broke .....or the motor may be gone in it ....not sure if there are any fuses for the motor on your dryer .
If you can tip the dryer over the bottom is usually open and you can see the motor and belt from there
Jan 09, 2009 | Kenmore 64952 Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Whirpool electric dryer: heat turns on but no rotation
Your problem could be as simple as a broken drive belt.. or an overtemp switch.... If you've never replaced the drive belt.. then that is in all probability your problem.. If you reach inside the dryer drum and try to rotate it.. does it offer any resistance like it is turning a motor pulley system or is it free to rotate with very little resistance ( would suggest the belt broke).. If the cost to repair exceeds the cost to replace then you'd be better off replacing.. However ..if it is just a drive belt.. then I would just replace that.. Hope that helps...
Aug 24, 2008 | Dryers
Kenmore gas dryer
kuki, on a gas dryer, if the thermal fuse is blown, it will rotate but will not heat. If your dryer front has a lower panel, the fuse will be in front behind the blower housing. If not, it will be in back just like this pic. Ohm it out or jump it out temp to see if that is the problem. Post back, Catriver
Aug 31, 2007 | Whirlpool LER5636P Electric Dryer
Zanussi TC7102W Electric Dryer Logo
53 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
