Question about Maytag Neptune MAH5500B Front Load Washer
Hello i need apart for may washer model # is mah5500b and the parts is pressure swich pump . but i cant find that part, where i can calla for that part?
  • Maytag Master
  • 3,740 Answers
Item 3 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47812
You can also go to www.searspartsdirect.com and enter your model number MAH5500BWW under "Find it fast" It also comes up as item 3 there. Note there is a 3A and 3B also.
Phone numbers for both are listed on the websites
Thanks for choosing FixYa,
Kelly
Posted on Oct 05, 2010
    President:
  • 2,468 Answers
Its a whirlpool part it should have a number on it such as 22004500 level 2 or 22003728 and any appliance parts store should carry it,i know its a maytag,but whirlpool is with them now and produces most of their parts
Why won't my Maytag Washer extract water properly from clothing after going through the complete cycle?
Belt tension spring faulty, belt loose. Pump partly blocked, look for coin caught in hoses. Internal clutch failed in gearbox, replace gearbox. Gearbox pulley wrongly adjusted, remove pulley, re-grease, re-install with correct clearance.
Dec 18, 2013 | Maytag Neptune MAH5500B Front Load Washer
Have an neptune washer with nd signal. installed a new control panel and still getting nd message. what to do?
Hello, Thank You for using FixYa. I will be helping you today.Check the little hole and cap for a blockage on the drain pump that connects to the pressure switch that is connected to the drain pump.It looks like a black cap on the drain pump. If the drain pump works and there is nothing blocking the hole replace the pressure switch
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Maytag Neptune MAH5500B Front Load Washer
Removed both water pump hoses, No blockages drum still has water init. Is this normal? Won't drain and go to final spin. Pump clean and spins free. Maytag Neptune MAH5500B
Water pressure switch adjustment or clogged. Check the small connecting hose to the switch body.
Final spin command signal generates from this part only.
Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer will not drain . I washed bathroom rugs that fell apart leaving excess fibers that I beleive plugged up the holes that allows drainage. A few gallons of water is still sitting in my washer and...
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag washer leakes, all the water runs out on the floor.
Remove the rear access panel to check the source of the leak. The drain pump is most probably broken or the sump hose is damaged or detached from the tub.
Drain Pump Removal/Replacement Procedure (Maytag Neptune MAH5500B)
  1. Safety first. Unplug the machine.
  2. Remove the hose clamps and hoses from the pump.
  3. Disconnect the wiring harness from the pump and the pressure switch terminals.
  4. Rotate the pump assembly counterclockwise and remove it from the base of the washer.
  5. Remove the plastic bag covering the pressure switch.
  6. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
  7. Grasp the pressure switch and lift the nipple off the pump cap.
  8. Install the pressure switch on the new pump in reverse order of the removal steps.
  9. Install the new pump in reverse of the removal steps above.
Jan 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wont drain have cleaned out pump for coins anything else it could be
You cleaned out the pump, but did you check it out? Take a flashlight and look into the suction port on the pump. Check the impeller for broken or missing blades and see that the impeller rotates freely. If there are broken/missing blades or if the impeller will not rotate freely the pump is defective.
Aug 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer wont drain
The washer's pump unit has stopped working. It may not me getting the signal to pump after the wash cycle (controller problem) or the pump has let go and needs to be replaced.
Aug 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
CONTROL BOARD?
the board is the easiest fix you can have, just take the backsplash apart & swich it out, order from marcone.com with your model #
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
