Question about Maytag Performa PAV2200
Maytag performa series washer
Went in to change clothes over and realized that the washer had not finished the rinse cycle. I changed it to the spin setting and it acted normally. Tried to wash again but this time it ran water for few seconds and then quits. What could be wrong?
  • Anonymous Jun 06, 2008
    my maytag performa washer will not spin or go into any other cycle other than when you first start it and water start like you would be washing normally.
    the washer used to make a loud noise when it started to spin. Now it won├Ęt even go into a spinning cycle.
    Is this washing machine junk
I purchased a Maytag Performa washer in 2003 and experienced the same thing. A service call found a loose electrical connection behind the switch panel. The washer has worked fine since.
Hope this helps.
Posted on Sep 04, 2008
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
Maytag Performa, Noisey spin cycle, now does not work
the belt may be old and stretched/slipping...if it is stretched and slipping it will cause the squealing .............otherwise, check the pulley for the belt/motor to see if it is okay and the motor itself copuld be worn out if the belt looks ok............be careful, you can get zapped if you touch a wire and also if the motor is burned up it can cause a fire so watch carefully and you should be able to see which of these possibilities are the problem..............
Feb 13, 2010 | Maytag PAV2300 Top Load Washer
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
Series of clicks..then dead
The load size adjustment only changes the level of water used, this could not cause a fault,sounds like a faulty rinse valve or depending on model a faulty or blocked pump. Regards Engineer
Feb 27, 2007 | Maytag Performa PAV2200
Washing Machines Logo
876 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
