Question about Electrolux EW1000i Front Load Washer
E70 lock on elctrolux dryer model edc77570 type p542766
Error code E70 What is it?
E70 Stuck key Continuous key read for 60 seconds. Power down (unplug) machine, wait 30 seconds and retry. Use t04 test to test keys. Separate control and control housing from front panel - clean and remove foreign debris. Ensure all keys can be operated freely without sticking. Replace control panel if actions do not resolve. Maybe this will help
Oct 27, 2013 | GE Adora Front Load Washing Machine Washer...
My elctrolux drier keeps displaying error E63
That means that the heater coil has burned out. Replace it.
Dec 24, 2012 | Electrolux EIED55HIW Electric Front Load...
E70 error code on electrolux dryers inspire, it is working but dries the clothes to damp then this code comes up
Hi Nora King - Error code E70, typically means that there is a communication error with the outlet/inlet control thermistor that has an open or short circuit. You will need a certified professional to check the resistance of outlet/inlet control thermistor and check wiring for either short or open circuit.
Sep 17, 2012 | Electrolux Dryers
Water is draining continously from tank
its over filling its the soilnoid valve letting by u will need to replace it
Aug 26, 2012 | Electrolux Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
My nokia E70 in lock. pls unlock code
In order to unlock the Nokia E70 mobile , get the unlock code here theunlockarena select country & network provider , then using unlock code specified in it proceed unlocking your mobile & gain solution .
Jul 07, 2011 | Nokia N70 Cellular Phone
Where can I download the user guide for a Kelvinator 6711A20013U air conditioner?
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Is it helpful?
Dec 26, 2010 | Electrolux Heating & Cooling
Door locks
1. On a internet search enter your model number
2. Then type your model number in the search engine.
3. Type in owners manual.
4. Finally hit enter. More than likely it will be in pdf file and you will need adobe reader to open it.
Dec 15, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Electrolux EW1000i Front Load Washer Logo
126 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
