Question about Rheem EcoSense by 4.2 GPM Tankless Water Heater LP Gas
I have a natural gas eco Sense tankless hot water heater.I will turn it on and it will work fine. then I shut it off and if I turn it back on I will get an error code c2 will blink then 11. I will then turn it off, the keypad will reset to the temp. number, I will turn it on and get the same message. may after about 2 or three time then it will ignite and work.
    Problem Solver:
  • 6 Answers
Try cleaning your spark rod inside the unit and the other rod next to the spark rod on the side of the unit. Takagi use a emery cloth, rheem brass brush, noritz a emery cloth. but make sure that both of the rods that are in the flame chamber are very clean. It miss reading because of build up on the rods.
Posted on Oct 06, 2010
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Nov 10, 2014 | Rheem Tankless Hot Water Heater...
Ptg 74pvn 2 rtg 74pvp
copy following links for rheem/eco-sense error codes, manuals, required yearly maintenance, support number and resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Probably bad PC board, or bad remote control
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 22, 2013 | Rheem EcoSense by 4.2 GPM Tankless Water...
Rheem Eco Sense PTG2-42PVV error messages
Open following link for rheem tankless resources, including error codes and typical maintenance.
May 18, 2012 | Water Heaters
I turn it on and it looks like everything is fine we use the hot water and it turns off and starts flashing C-7 & 76 before when it would shut down we would pull the pour cord and wait a minute and...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troublshoot-Rheem-Tankless-water-heater.html
Read manual thoroughly for troubleshooting and yearly maintenance requirements.
The manual has basic error codes and possible self-repair tips, but the same problem on one person's unit can be a different problem and different solution on another unit.
Repair most tankless problems yourself, same day, any brand for about $330
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 09, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm: hi i have a rheem tankless water heater, with flas...
Sounds like you may have the wrong type gas going to this? Is this an LP gas or natural gas unit? will say on label. Natural gas units run only on natural gas ditto for LP. Could be issue with manifold pressure settings. Could be obstruction in exchanger or vent. Have a authorized technician check over
May 17, 2010 | Rheem Tankless Hot Water Heater...
After water to house was shut off, my Noritz tankless water heater is on but won't produce hot water. On the unit, the light indicating that the burner is on stays off now.
you probably had debris get into the filter or flow sensor when the water was turned back on. I'd recommend checking the filter first and if that doesn't work, call Noritz Tech support to help you with the flow sensor.
the filter is a black plug located on the cold water line (labeled cold on the bottom of the unit). It points torwards the left.
Apr 14, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
The hot water will not come on intermitently. I
if your on a private well, it sounds as though your loosing enough water pressure to shut the heater off,.(which is right before the water pump comes on),....tankless heaters turn on by sensing water flow, and of course off when flo stops,......water pressure tanks often need to be re-charged with air for pressure to stay even,....does your water pressure fluctuate?
Jan 10, 2010 | Rheem EcoSense by 7.4 GPM Tankless Water...
Rheem EcoSense by  4.2 GPM Tankless Water Heater LP Gas Logo
269 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
