What are the carrier 8000ts led error codes? - Heating & Cooling
  • 3,740 Answers
They are listed inside the front panel of the main unit.
LED CODE
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST
DIGIT DETERMINED BY THE NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY
THE NUMBER OF LONG FLASHES.
STATUS
11 NO PREVIOUS CODE - Stored status code is erased automatically after 72
hours. On RED LED boards stored status codes can also be erased when power
(115 VAC or 24 VAC) to control is interrupted.
12 BLOWER ON AFTER POWER UP (115 VAC or 24 VAC) -Blower runs for 90
seconds, if unit is powered up during a call for heat (R-W closed) or R-W opens
during blower on-delay.
13 LIMIT CIRCUIT LOCKOUT - Lockout occurs if the limit or flame rollout switch is
open longer than 3 minutes.
- Control will auto reset after three hours. - Refer to #33.
14 IGNITION LOCKOUT - Control will auto-reset after three hours. Refer to #34.
21 GAS HEATING LOCKOUT - Control will NOT auto reset.
Check for: - Mis-wired gas valve -Defective control (valve relay)
22 ABNORMAL FLAME-PROVING SIGNAL - Flame is proved while gas valve is
de-energized. Inducer will run until fault is cleared. Check for:
- Leaky gas valve - Stuck-open gas valve
23 PRESSURE SWITCH DID NOT OPEN Check for:
- Obstructed pressure tubing. - Pressure switch stuck closed.
24 SECONDARY VOLTAGE FUSE IS OPEN Check for:
- Short circuit in secondary voltage (24VAC) wiring.
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than
five minutes, inducer shuts off for 15 minutes before retry. Check for:
- Excessive wind - Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Restricted vent
- Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used)
If it opens during blower on-delay period, blower will come on for the selected
blower off-delay.
33 LIMIT CIRCUIT FAULT - Indicates a limit, or flame rollout is open. Blower will
run for 4 minutes or until open switch remakes whichever is longer. If open
longer than 3 minutes, code changes to lockout #13. If open less than 3 minutes
status code #33 continues to flash until blower shuts off. Flame rollout switch
requires manual reset. Check for: - Restricted vent
- Proper vent sizing - Loose blower wheel - Excessive wind
- Dirty filter or restricted duct system.
- Defective blower motor or capacitor. - Defective switch or connections.
- Inadequate combustion air supply (Flame Roll-out Switch open).
34 IGNITION PROVING FAILURE - Control will try three more times before lockout
#14 occurs. If flame signal lost during blower on-delay period, blower will come
on for the selected blower off-delay. Check for: - Control ground continuity
- Flame sensor must not be grounded
- Oxide buildup on flame sensor (clean with fine steel wool).
- Proper flame sense microamps (.5 microamps D.C. min., 4.0 - 6.0 nominal).
- Gas valve defective or gas valve turned off - Manual valve shut-off
- Defective Hot Surface Ignitor
- Inadequate flame carryover or rough ignition
- Green/Yellow wire MUST be connected to furnace sheet metal
45 CONTROL CIRCUITRY LOCKOUT Auto-reset after one hour lockout due to;
- Gas valve relay stuck open - Flame sense circuit failure
- Software check error
Reset power to clear lockout. Replace control if status code repeats.
If status code recall is needed, briefly remove then reconnect one main limit wire to display
stored status code. On RED LED boards do not remove power or blower door before initiating
status code recall. After one status code recall is completed component test will occur.
Thanks for Choosing FixYa.
Kelly
Posted on Oct 05, 2010
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Code 24 on carrier weathermaker 8000ts
Turn power off to unit. Open air handler and take a picture of the low voltage (tstat) wires and where they are landed. Remove all thermostat wires from control board. Then replace the 5 amp fuse that is likely on the board. Fuse likely looks like one for a car (blade style). Put a jumper (small piece of wire) from the R terminal to the G terminal and turn power back on to unit. This should bring on the indoor blower. Let me know how that goes!!
May 12, 2017 | Heating & Cooling
I have an 18000BTU unit that has an LED that flashes 5 times and then stops,could you pls advize as to the error code of the LED flashes.
You haven't mentioned the brand name. As the error code changes brand to brand I give some solutions. Check with your unit.
e-5 Outdoor activation of compressor over heat protection-Clean condenser coil and check out door f.motor speed. If less replace capacitor.
e-5. Blower motor lock Rotate manually. If hard to rotate, replace bearings or motor. If easy to rotate, replace capacitor.
Please mention brand name and other full details to get solution quickly. Thanks.
Jan 10, 2011 | Carrier 36KCARMS Air Conditioner
I have a carrier furnace and a error led code is one long then an immediate short folliowed by another short before the long
Lucky for Light Emitting Diodes huh? (led)
I'm looking at a legend, on a Carrier furnace door, right now.
One long followed by two short is the "twenty one" code.
Here's what the door sticker says;
"EACH OF THE FOLLOWING CODES IS A TWO DIGIT NUMBER WITH THE FIRST DIGIT DETERMINED BY THE NUMBER OF SHORT FLASHES AND THE SECOND DIGIT DETERMINED BY THE NUMBER OF LONG FLASHES."
Look on your legend, inside the door of the furnace, to find the code diagnostic recommendation.
Make sure to read the codes several times and see the code from the beginning so you make sure the code starts with that digit.
Knowing this furnace means; the code diagnostic recommendation is just that, a suggestion. It will not tell a trained tech what to fix, only a starting point and tell-tale signs.
Code 21 is the gas valve lockout, and will not reset. May be a gas valve, relay or control board (most likely). Call someone.
It's complex for a trained person too, so if you're not familiar, this isn't something to make a mistake on.
Luck to you. Let me know how you get on.
myairfixer@gmail.com
Dec 23, 2010 | Carrier Heating & Cooling
We have an infinity 96, about 5 years old, has always run well. In the past month, it has shut off overnight twice. The LED indicator flashes code 25, set up error. a simple power off resets it to run...
This unit stores up to 9 error codes. Follow the directions to retrieve the other 8 to see what is registering. If you are getting a set up error, have the gas pressure re calibrated. There are two or three pressures that need to be set.
Feb 07, 2010 | Carrier Heating & Cooling
I have a domestic carrier air-conditioner in
There should be an Error code cheat on the back of the electriacl cover that explains what each blink or sequence means. If it doesnt have one then just go online and look up the Model/Serial number up on the Carrier website and it should tell you.
Jan 07, 2010 | Heating & Cooling
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
The fan on my Carrier cental air system is on, and I can't
The fearute that is running your fan so often is designed to provide even, consistent temperatures throughout your home as opposed to hot spots and cold spots. Some customers find this feature to be an annoyance or a waste of electricity. IF you would like to be able to turn off that blower you can have it wired to a switch which would give you either manual off and on or even a timer.
If you want to do this in a barebones fashion you cojuld just find the circuit breaker that controls it and turn it off when you don't want to use any function of air, heat or cool.
Apr 30, 2009 | Heating & Cooling
Carrier furnace blows heat constantly!
recheck your wiring iunside of the furnance around where yuou were working, you may have wired it wrong.
Dec 15, 2008 | Heating & Cooling
Heating & Cooling Logo
3,888 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
