Question about Apple MacBook Pro Notebook
My Apple MacBook Pro gives me an instruction to change my DVD drive region and says I can only do this 5 times. As I travel world wide I need to change more often.My previous Apple computer had no such restrictions. How do I disable this? Thanks
    President:
  • Apple Master
  • 1,932 Answers
Please view the below video and this will help you to make you mac region free
http://www.youtube.com/watch?v=gayeBeyp7Rk
Below is the French site which is mentioned in the video
http://www.powerbook-fr.com/dossiers/dvd_region_free_en_article30.html
Thank You
Posted on Oct 05, 2010
Brand new apple dvd drive will not accept dvd
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 24, 2014 | Apple MacBook PC Notebook
I am from New Zealand . I recently played a DVD disc from the U.S. which is region 1. I had to change the region setting on the bluray drive to play it. I tried to play a region 4 disc on it, and after...
Ask the people you purchased the bluray drive to give you instruction on how to reset (usually is about 5 times and then it gets stuck in the last region used, the Blu-ray region is set in the playback software, not the drive.). You may also want to try re-install the software, which resets it. Good luck.
Mar 05, 2011 | Computers & Internet
Sims 3
No problem.
Here is what you need to know:
The regional code for the US is (1).
You can change your DVD Region code up to 5 times on your Mac.
Review the information on DVD Regional codes via this Apple Support link to change the region code:
DVD Region Codes - DVD Player
Let me know if this Apple data helps!
Regards,
-Mactechtrainer
Jan 29, 2010 | Apple 24" iMac Desktop
Laptop dvd drive region locked in R1, need to be mostly R2
keep in mind you can only change the region 5 times and cannot change it anymore after that (regarless to windows reinstallation , its a hardware thing) you might wanna consider purchasing "dvd region free" or use a 3rd party region free firmware to bypass that
dvd region free - http://www.dvdidle.com/dvd-region-free.htm
3rd party firmware - http://www.rpc1.org
Dec 24, 2009 | Computers & Internet
Error -70001 problem changing dvd drives region
when changing the dvd region for the fifth and final time. you need to insert a disc which only plays one region (the one you want) in my case region 2. if the disc can play more than one region then it wont set.
Sep 30, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Is there an application (for Mac' Leopard) to change region code?
You can 'flash' the Firmware of the drive.
or
buy a Mac-compatible external DVD Burner.
They are Region-Free and you dont have to mess with your mac
Sep 02, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
Audio driver for Macbook pro
The drivers for XP are on the official OS X Leopard DVD. Install this when running XP and then run the Apple Drivers Set up on the disk.
Jan 20, 2009 | Apple MacBook Pro Laptop Computer with...
Acer DVD problem
ok, try this...
goto: http://files.rpc1.org/
find your model (i think its in section Acer/Benq) and download the hacked firmware (region free).
Now that your drive has had its region-checking facility disabled you also need to remove the checking that is built into Windows and the DVD-playback software. The easiest way to do this is with Dvd region killer or better find AnyDVD. Download it and install it on your computer.
Jul 09, 2008 | Computers & Internet
Apple MacBook Pro Notebook Logo
19 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
