Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
B/s lawn mower, when primed engine starts but stops when petrol is used up.I have cleaned air filter, which looked ok to no avail.
  • 4,340 Answers
Your description sounds normal, gas engines stop when guel is used up, but I presume that you meant after the prime fuel is used up. This sounds like a fuel delivery problem, and most likely within the carb itself, you need to disassemble and clean out all blockages.
Posted on Oct 05, 2010
Why does my 6.5 hp kohler lawn mower keep pulling oil into carb air filter
Its to stop the dust blocking the filter. The filter should be cleaned with petrol every 4 to 6 months to remove the dust & oil build up, cleaned in/with petrol and re-oiled. Its also good to clean the filter housing each time you clean the filter
Sep 26, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Pushmower won't start?
A few quick steps can help you diagnose the problem. Remove the air filter cover and air filter. Spray a shot of carb cleaner into the carb and try to start the mower. If the mower starts on the prime then you have a fuel issue. Be sure your fuel is fresh (less than a week old. Fuel is bad at 21 days old) and clean or rebuild the carb. If the mower wont start on the prime then it is an ignition or compression problem. Start by checking that the stop cable is pulling the bail off ground sufficiently.
Jul 27, 2014 | Toro Power Lawn Mower
Dear Sir, I have an Mountfield m4 major petrol lawn mower some 20 years old. It starts O.K. but the engine will stop after a few minutes.By turning the choke on just before the engine stalls, will keep it...
sounds like the needle valve Seat is slightly clogged and the gas entering the Carburetor cannot keep up with the Draw from the engine.
Oct 05, 2013 | Garden
LAWN MOWER STOPS WHEN HOT WILL NOT START UNTIL COOL
heat related problem are more likely to be a bad coil look under the upper engine cover and see if there is a mouse nest stopping air flow threw the cooling fins
Jun 03, 2012 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
My Lawn mower will not start, there is no spark, when the new plug is held against the casing. All else looks fine, new oil, new petrol, clean carb, filter. It worked ok up to a month ago, then would only...
It also could be the stop switch is not opening up. On mower you have a stop bail that a cable is attach to the engine if this cable does not open the stop switch, when the bail is pulled back, the mower will not allow the mower to start. The stop cable may need to be replaced because it is stretched out. HTH
Good Day. mate.
Oct 27, 2009 | Garden
Nannie what can be wrong with my power devil petrol lawn mower the engine wont keep running then cuts out petrol and oil ok
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Jun 23, 2009 | Mtd 22" Yard Machine Push Mower
Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Mar 19, 2009 | Garden
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
244 people viewed this question
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
