Question about Nikon Action Binocular
I can't focus the binos anymore looking through both lenses at the same time, it's distorted
    Brigadier General:
  • 3,006 Answers
You have asked about what is one of the most common binocular problems. I hope that you don't mind if I paste my generic answer below as there's no point in reinventing the wheel. If the answer does not provide a solution then please state your exact Nikon Action model and add any extra details which may help.
Your binoculars either have a bent or broken yoke assembly (the bit which carries the eyepieces) or one or more prisms have came unseated.
The first repair involves replacing the entire yoke assembly: the part is expensive in comparison to the retail cost of a new pair of binoculars and with labour charges on top is not usually a cost-effective repair except on really high end expensive models and you can buy a brand new pair of Nikon Action binoculars for less than GBP£90.
The second repair is straightforward and fairly quick for anyone with the right collimation equipment, but the screw(s) need to be secured with thread-locking liquid afterwards.
I hope you manage to use this information to fix your binoculars or at least that it assists you to choose your next course of action. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 08, 2010
How can you fix a lense from not wanting to auto focus anymore?
Look for a switch on the lens barrel "AF - M", "A - M" ,"M/A - M",etc. Make sure the lens is set to AF or M/A. These stand for Auto Focus and in the case of the last "M/A"; manual override of Auto Focus. An "M" alone indicates it is in manual focus mode.
If in an auto mode, and it will not focus still, there could be an issue with the focus motor in the lens or contacts on the lens that provide power and communication between the lens and the camera body. In either of these cases, you may need to have it checked out professionally.
Jan 30, 2012 | Nikon Cameras
My HVR-V1U has a focus problem. In manual focus mode, when I zoomed in and focus and then zoom out, it is not in focus anymore. But if I leave the camera in auto-focus it is fine. I don't see a way...
That's the backfocus problem. Take your camera to a Sony service.
If the lenses are ok, they will do an adjustment. If the lenses are defective, they will
replace the lenses, but that costs much.
Sep 22, 2011 | Sony HVR-V1U Mini DV Digital Camcorder
One of the lenses don't focus
You have the classic signs of the most common binocular fault: a bent or broken eyepiece carrier yoke.
The cause is usually due to the binos being dropped or stored standing on the eyepieces. The only cure is a replacement yoke, but the repair is rarely cost-effective unless the binos are really expensive and top-quality models. Yours probably do fall into that range, so contact an optical repair specialist for an estimate.
Broken/bent yokes cannot be repaired: If bent, then it's near-impossible to unbend them accurately enough and in any case the process will always either break the yoke or will severely weaken it. Broken yokes cannot be glued together as the contact point is just too tiny for the loads it carries, and as it usually bends before breaking you'd simply end up with a bent yoke afterwards even if you could glue them.
Sep 10, 2010 | Zeiss CONQUEST BINOCULAR 8X30B MC BLACK
Minolta Standard Zoom 7x to 15x x35 binoculars
yes it is fixable its the inner lenses coming loos and they will need to be fully striped down and cleaned the body air blasted out and then all lubed and put back together before being re-gased,,,standerd overhall job,,,pricy too,,,
Mar 03, 2010 | Optics
We had a fire and my binos got smoked inside. I took apart the front and cleaned the prisms in front and lenses. How do I access the back prisms? How do i get the cover off the prisms at back of binos.
most prisms have coating on their air to glass surfaces. Chances are you have already degraded their original quality, even with the smoke gone. From past exp. you will be better of getting another bino...
Feb 16, 2010 | Bushnell Legend 19-1050 (10x50) Binocular
Minolta Compact AF 8 binocular continually focussing
My Binos are doing the same thing, I think it is some fixed mode it is stuck in. Anyone know how to get is back to normal working? Maybe the big AF button is stuck on?
Help please as I can't find my instruction manual.
Feb 07, 2010 | Minolta Compact Binocular
Dropped new Celestron Skymaster 15x70 binoculars. Nothing appears broken, but now have two images. Can I repair this. and how? Thanks. Dan
Don't "unscrew" the binoculars. there are no user servicable parts inside. the collimnation adj screws are beneath the rubber boot just under where your index fingers rest when looking through the bino's. use a jewelers screwdriver to tease the boot up and stick a small nut or something in. then put the binos on a stable surface and play with the screws a bit while watching the images. you can get them pretty close this way.
Jul 21, 2009 | Optics
Unscrewing lenses
Hello toccata, It sounds like your lens mount is cross-threaded. Have you gotten a lens off and looked closely at your camera lens threads. Are they crunched together. You may need to get your cameras lens mount replaced and check all your lenses and see if the threads aren't cross threaded. If a lens has bad threads, don't use it anymore.
Jul 28, 2008 | Olympus EVOLT E-300 Digital Camera
Focus is completely out of whack
i'd probably say try a repair place. It's a problem with retractable lenses.. better quality, but prone to problems.
Mar 30, 2008 | Canon PowerShot A75 Digital Camera
My rebel xt doesn't seem to have good focus anymore?
HI ,need to adjust in the day time adjust day light icon, if when night time need to camera in the presence of bulb need to ajust bulb or flourescent. so that it make shaper image also in iso im use 100 iso also ca observe in group picture have a\djustment for a group just navigate the good idea or advance technic og photography.
Jan 23, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon Action Binocular Logo
265 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
