Question about GE Lands Phones
I have GE model FES2-9297. When i connect it (with or without its power adaptor) to phone jack and call the number on it, it does not ring . If i connect it to another phone jack of different carrier it rings ok. Probably there is difference on the signals send on the line by each carrier, any solution? Any programming that can be done on the phone to have it ringing ?
  • 84 Answers
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Posted on Feb 14, 2008
SOURCE: GE dECT 6.0 Cordless Model 28112 Series
phones say do not disturb and will not ring
Posted on Feb 28, 2008
SOURCE: ge cordless phone model # 28111ee2-a is on do not distrub
There is a do not disturb button on the base of your phone - if it's red it's on. Press it to turn it off. It is on the main base and works for both headsets.
Posted on Jan 20, 2009
SOURCE: GE phone has stopped ringing
I had the exact same problem and tried everything. It wasn't until I unplugged and main base from the electrical outlet for a few minutes and plugged it back in -- for some reason that made everything work. It is worth a try. We had some minor electrical outages in the last week due to weather so I assume that screwed something up.
Posted on Feb 02, 2009
SOURCE: phone ringing after power failure
I believe you have to reset the intercom system, meaning you need to reassign one or all of the phone's intercom numbers. To assign intercom # ( found on page 10 of the manual which you can download online)
1 Do NOT lift handset
2 Press the following 3 buttons (in order) PROGRAM, STAR, and then POUND
3 Enter two digits (the number you want the phone to be)
4 Press the INTERCOM button and you will hear a tone - then youre all done.
Posted on Feb 17, 2009
I have tried every configuration of the wiring I can think of. I have 2 jacks and a Ring Selector for the fax machine.
What is the make or brand/model of the phone you are referring to? Does it has a line 1/2 selector or a ringer selector on the panel?
Maybe the phone you have has a selector on its side.
I need more info.
Best regards.
Sep 01, 2015 | Lands Phones
Model 21518 GE Bluetooth Telephone Adaptor
I see the same thing and it appears that this is the way it works. Without the landline you will get the beeps but can still make and recv calls. After the beeps, dial #1#phone-number#, and it will call that number. Guess that is what they mean when say works without landline.
Apr 12, 2009 | GE Lands Phones
There is an undocumented solution to link difficult devices. Instead of pushing ad releasing, hold either button down until you get a FAST BLINK and then try linking again.
Jun 29, 2008 | GE Bluetooth In-ear Headset Wireless...
Printer is not working.
You can first try to connect the unit to a different wall jack , if the adaptor is not warming up after a few minutes , its a concern with the power adaptor .
U can call Hp parts store to get the adaptor.however u need to give them the part number (which will be located on the adaptor itself )
Parts Store Number - 1-800-227-8164.
Thanks.
May 16, 2008 | HP DeskJet F380 All-In-One Printer
Does not ring
is the ringer on the base or phone on? check that first.if that's ok, then plug a regular corded phone into the phone jack and see if there is dial tone.if there isn't any, try other jacks in the house. if still not working, call your phone company.
wg
Feb 11, 2008 | GE 27998GE6 Cordless Phone
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
Jan 28, 2008 | GE 29878GE1 Digital Answering Machine
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Dec 08, 2007 | GE 28112EE2 Cordless Phone
VOIP will no ring
Just "VOIP Phone" is not enough information to help you. There are many hundreds of different phones, connections, & setups you could have. What type of phone (make, model number)? Is this a VOIP phone connected through a home network, cable modem etc.. for home use? Is it a single line phone connected to a VOIP box connected to your cable modem? Is it a VOIP phone system connected to regular copper phone lines? Are you using a VOIP phone at home connected to a VOIP phone system at work?
Nov 17, 2007 | Lands Phones
Lexmark
I hope u are connecting the lexmark X7350 the right way.. i.e... telephone wall outlet to line jack on the back and ext port to the Physical phone... If you are then Could be a case of the adapter that lexmark supplied is not working or the Ext port of the printer itselt has the prob.. check again with lexmark support and may be you can get it replaced...
Feb 15, 2007 | Lexmark X7350 All-In-One InkJet Printer
Lands Phones Logo
69 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
