Question about GE XL1800 1100 Watts Microwave Oven
Not heating up food / drinks. makes a "crackling" sound when turned on
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 05, 2010
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
It wont heat up my food
Hello there and thank you for choosing fixya
Whenever a microwave will not heat up food this is normally due to a failure of 1 of 3 things
First is the mengatron Magnetrons are made of magnets that conduct an electrical circuit, thus creating the energy needed to cook food in the microwave. Although magnetrons are durable, they will eventually begin to fail. If a microwave begins to lose the capacity to heat, the problem is most likely the magnetron. Testing the voltage in the magnetron is done using a device called an ohmmeter it is tested like this
Unplug the microwave from the wall and turn it around so that you are facing the back of it.Remove the screws in the back cover and the sides then remove the outer shell it should slide back a bit then up and off
Locate the high-voltage capacitor, an oval-shaped cylinder, and place the tip of an insulated screwdriver on top of one of the metal terminals protruding from the top of it. Tilt the other end of the screwdriver downward slightly until the metal part touches the other metal terminal. You may hear a popping or crackling sound, which is energy being discharged. Remove the screwdriver from the terminals.
Place the tip of screwdriver back onto the first terminal and tilt the other end of the screwdriver until the metal touches the metal base that the capacitor sits on. Hold for a few seconds, during which time you may hear a popping sound. Repeat the procedure with the other terminal. i will finish this in a second post
May 17, 2011 | Sanyo EMS2298R Microwave Oven
I got this Sunbeam SGB8901 microwave that doesn't heat anything. It turns on, rotates drink or food, and it sounds like it's working fine, but once the timer counts down, you pull out the drink and it's...
That will either be the magnetron or the power transistors inside having failed. If you get lucky a repair shop might be able to fix it reasonably but usually it is time to look for a replacement as the repairs cost more than the new one.
Jan 24, 2011 | Microwave Ovens
Hear crackling sound and not heating food, what can that be?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101//./.
Oct 21, 2010 | KitchenAid KHHS179LSS Convection /...
Crackling and popping sounds when you heat up food
thats normal water expanding and boiling off from the microwave boiling those tiny water pockets in food... sounds like popcorn sometimes.
Cover your food with a paper towel to avoid spatter on the ceiling of the microwave when this is happening.
Sep 12, 2009 | Sharp Microwave Ovens
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heat
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 28, 2007 | GE XL1800 1100 Watts Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
258 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
