Question about Cameras
Canon digital camera
When i turn my camera on i get a message that says "memory card error". i bought a new memory card but that did not fix the problem. what can i do to fix it?
  • 3 Answers
Maybe something is stuck in the memory card part of the camera...
Posted on May 28, 2008
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
S400 memory card error. Turn on camera - display "NO IMAGE MEMORY CARD ERROR". Can not take pictures, can not display pictures. Have several memory cards - same message, different cards. If the camera...
The internal BIOS battery has run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
Feb 21, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
New San Disk memory card not working
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
Jan 09, 2009 | Canon PowerShot SD600 Digital Camera
Memory Card Errors with Canon PowerShot S3
There most definitely is a solution to this problem. Follow this link for a step by step fix for the memory card error. It requires taking the camera apart but if the warranty is expired you have nothing to lose. Fix worked fine for me.
Nov 22, 2007 | Canon PowerShot S3 IS Digital Camera
Memeory card error
The problem seem to be the card reader in the camera have contact problem, first thing is to ensure is there anything inside the hole where you insert your mem card, second ,try to use contact cleaner to clean up the card reader .hope it help.
Aug 20, 2007 | Canon PowerShot A430 Digital Camera
Memory card error
Either the camera or the card is faulty. There is not a setting which will cause this problem. Try a different memory card, if the problem persists you will need to get the camera repaired.
May 07, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Memory card not reading in canon a75
So as not to spoil your vacation, go buy yourself a new compact flash card locally. They should sell them anywhere electronics are sold, including WalMart, etc. See if you can get this new card to work in your camera. If so, then you can work on trying to get your current CF to work, by trying to format it in the camera. If you can't get a new CF to work in the camera, then you likely damaged either the pins in the CF socket in the camera, or some switch that is pushed when the card is inserted (to tell the camera there is a card in it). It is unlikely you will be able to have this fixed during your vacation, unfortunately.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
No memory card error on canon powershot a400
Maybe you have to format the card before the camera recognizes it
Dec 04, 2006 | Canon PowerShot A400 Digital Camera
Cameras Logo
88 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
