I want to add 4gb ddr2 to this board can i ?
    Guru:
  • 382 Answers
Yes, make sure that your Operating System is a 64Bit version because if you only have a 32bit OS then it will only recognize 3GB of RAM and the 1GB will go to waste.
Posted on Oct 05, 2010
Please tell me jetway I31GM4-Lf mother board ram support per slot
  1. Dual Channel DDR2 memory technology
  2. 2 * 240-pin DDR2 DIMM slots
  3. Supports DDR2 800/667 non-ECC ,un-buffered memory
  4. Max.4GB
Nov 02, 2014 | Computers & Internet
Why cant i get my 4x 2gb ddr2 800 to work on my asus p5qc mobo? it will run fine with just 4gb 2x ddr2 800 but when i add the other 2x ram i get black screen at boot
Be sure to check which slots you are putting them in, stay within the same colors as to which needs to be put in.
This may be why, looks like your using DDR2
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots!
This may be the case for all speeds of DDR2
http://www.asus.com/Motherboards/Intel_Socket_775/P5QC/
Jul 16, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Computers & Internet
I have a p4m900mother board. i had 1gb ram in each slot. running 2gb ram. i replaced the one with a 2gb hoping to run 3gb ram but my pc will not boot. i have switched slots and still nothing. i can run up...
Make sure you have installed the correct type of ram into the board. Here are the ram specs for that board
• Memory:
Support DDR2 533/667 MHz
2 x DDR2 DIMM Memory Slot
Max. Supports up to 4GB Memory
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Biostar P4M900-M4 Motherboard
How to make geforce6100pm-m2 read both memory slots
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB*
? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB)
? Dual-channel DDR2 memory architecture
? Support DDR2 800/667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
Jan 31, 2011 | EliteGroup GeForce6100PM-M2 Motherboard
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
Compatiblity issue..
You may install up to 4GB of DDR RAM in this motherboard. It does not use DDR2.
This is from your manual:
Dual-channel DDR400 memory support
Employing the Double Data Rate (DDR) memory technology, the motherboard supports up to 4GB of system memory using DDR400/333/266 DIMMs.
If you would care for the manual, here is a link:
Asus P5P800-VM Manual
Thanks for using Fixya.
Apr 03, 2009 | ASUS P5P800-VM Motherboard
Memory Upgrade
Depends of your buget, Extra 4 GB DDR2 800 = $35 (total 8GB) I Have 4GB installed now seems fine, but all of this is necessary?
what application do you need to work?
Mar 27, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
