Question about RCA D52W23 52" HDTV CRT TV
My rca tv the picture is bending into the center of the screen and the letters are double and colors are off
  • RCA Master
  • 5,138 Answers
Press Menu then setup Look for Convergence,If you do Not See It listed then you have a Blowed Fuse FL231 on the Deflection Board.
It will be Located on the bottom left hand side Board with FBT flyback Transfomer on the right side of the FBT Look for 3 in a roll small brown looking caps ,These are Fuses, It will be the one in the Middle 0.06amps Partstore.com has them 1-866-925-7278
Posted on Oct 05, 2010
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
May 26, 2009 | RCA R56WH76 Projection Television
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Curved screen and double letters
i see this alot and rca shold issue a bulliteen. so i wrote advice on this. see fl231 problem under tips and tricks under my profile. this is a simple easy inexpensive repair. if this dont help let me know.
Sep 19, 2008 | RCA HD52W59 HDTV Projection Television
Picture convergence and double lettering
there is a bad dioded rca part # rca 259638 its in the convergence part of the tv it has to be replaced
Aug 03, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv picture
convergence i.c.s are defective.
Jun 28, 2008 | RCA HD52W58 52" TV
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA F27442 27" TV
1) Ask what the part location on the board is = IC301 for example..
2) Provide service #
3) Could be LA7612N
4) If they were not blowing smoke,why didn't they give you a
six digit RCA part # ??
....................................................T.
Nov 09, 2007 | RCA 32V420T 32" TV
Bending Picture
Convergence issues can be one or more of three different boards...in this case i would think it might be what is known as covergence power board.+ convergence amp board. both items very fixable and easy to replace. It would be difficult to determine however because if its the ssb board... then much more difficult to replace.
Sep 08, 2007 | RCA HD52W58 52" TV
RCA D52W23 52" HDTV CRT TV Logo
151 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
