Question about Bose 3·2·1 II System
Sound problem in cable mode the screen revcerts to "PCM 20" and the only sound is a repetitive loud stuttering noise
  • lewnaomi Jun 01, 2008
    Thanks for the help. I carefully checked the connections and found that they were loose. Thanks again.
There is a problem with the cable connection probably.
try another cable and check if the problem still persists.
if it still persists open the sound cover and check the connections inside the box.
Posted on May 28, 2008
What is the cause of a very loud, repetitive noise during spin cycle?
Sounds like the drum mounts are worn causing unbalance.
Sep 13, 2014 | Amana Washing Machines
What causes a repetitive, rapidly repeating, hammering or slapping sound in my rv roof top ac?
It's sounds like a critter may have started to make a nest in the blower motor fan. I recommend trying to clean out the fan motor squirrel cage.
Aug 02, 2014 | Heating & Cooling
Kitchenaid ykgrt607
Sounds like a Bearing on the Fan went bad (due to the Heat), replacing the Fan is the only fix.
Mar 03, 2014 | Kitchen Ranges
Mod: kuds30ixss6 - Making a loud noise
You are going to have to remove the spray bars and the filter at the top of the pump housing to see if something is stuck in the pump
Jan 06, 2014 | KitchenAid Dishwashers
2000 hyundai Elantra speedometer making noise and reading wrong
sounds like speedometer cable is gone or the gears between the cable and transmission which makes the reduction for sppedometer if no cable on that year they have a sensor
Nov 28, 2012 | 2000 Hyundai Elantra
The screen blanks out after approximately 20 minutes.
The power supply board is dead.Those high voltage transformers on the power supply board,one those power coil have a short in it,that why it cause this shutdown a have a loud electrical current noises.Tries websites like Shopjimmy.com.Ebay.com to buy a new refurbish power supply board for the replacement,should solved this loud electrical noises shutdown to tv.
Jul 10, 2010 | Sony BRAVIA KDL-40V3000 Television
Loud squeaking noise from speedometer/odometer
remove the speedo cable, lubricate it. if the sound still there, change the cable.
Apr 07, 2010 | 1987 Honda Accord
Bose 3·2·1 II System Logo
154 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
