Question about Home
My triton shower blew its fuse a couple of times and came back on when I 'flipped the switch' back up. Now it's given up altogether. What's the problem?
Assuming that the circuit and fuse protection you have is correct for the kw rating of shower unit the most likely cause would be an element failure however in order to be more definate relevent electrical checks would be required within the shower unit.
The Triton Service Dept who may be contacted by telephone on 0844 980 0750 would be able to arrange a sevice visit for you where the problem may be investigated further for you.
Regards,
Karl
TRITON TECHNICAL TEAM
Posted on Oct 06, 2010
My Triton shower Eco Excite 8.5kW keeps tripping fuse when turned on !!
Could be a pump jam, do you have hard water ? Could be scale build up.
Is the shower head blocked ? Unscrew just the head (leaving the hose line attached to shower) and try again. If that is the blockage, then clean it with descaler.
Also check you have a good pressure on your water supply going in the Triton. Low pressure can set off safety switches. Again, check for blockages.
Check also for breaks in wiring and check there is no water ingress at any and all connections.
Is it an old unit ? Is it serviced regularly ? .......finally....
are all the settings set to MAX ? if so then use lowest setting first.
If it works then move settings up gradually until it trips.
Any filters need to be checked if possible.
Good luck Red.
Jul 16, 2016 | Home
I have a triton t100xr shower as soon I press the on switch the power keeps tripping off, please can you help?
Chances the trip switch is not high enough,as in it may need a higher amp than what has been installed.You should be able to check this out by looking at the fuse board.If memory serves me right it should be 40 amp.Check this out in the paperwork that came with the shower. If not contact Triton, they are most helpful & easy to deal with. Their number can be got on Triton site. Be VERY careful when touching any wiring either @ the fuse board or the shower.
Apr 24, 2014 | Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
My Triton Millenium shower just stopped working mid shower. Power lights went off. Have checked fuse, power ok but will not switch back on. Any ideas.
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Jan 10, 2011 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Dec 09, 2008 | Home
Home Logo
668 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
