Question about Logitech LS11 2 Speakers
Speakers light up but dont work - Logitech LS11 2 Speakers
My logitech speakers do not work the green light and the sound is on when i push in the green button
Posted on Nov 21, 2010
Speakers dont work, led controls dont light up, diagnostic test does not work. My connections are correct and my drivers are updated. What is wrong?
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 28, 2010 | Altec Lansing ADA 885 Computer Speakers
I have a logitech LS 11 speaker and it is not working now. I dont see the green light on speakers working too.
have you rotated the volume dial that did it for me and switched the green light on if it doesnt work then they may be broken
Nov 14, 2010 | Logitech LS11 2 Speakers
I cant hear anything on my computer(cant get the volume working) jus got brand new computer 2day, mayb not plugged up properly, need help
there is 3 small circular sockets on the back of your pc they are coloured pink, light green and green or black plug your speakers into the light green one if that doesnt work try the other sockets one of them should work and dont forget to turn on the speakers usually the power button is on one of them...or if you dont have speakers try plugging the cable with the light green on both ends one end into the back of pc and the other end into the back of screen you might have to locate it where you see the connection cable on back of screen it might be hidden up under that part of screen ...good luck hope this helps
Sep 24, 2010 | Computers & Internet
I have a 2002 dodge ram 1500 quad cab. the gauges
Check your fuses. This a common thing that can come up often if you have changed from stock stereo equipment to after market, or just because of old fuses.
Once you locate the fuse box, it should give you a diagram of which fuses go to the different lighting systems in your car. Replace them and the problem should be fixed.
If the problem is not fixed from that, then have your wiring checked throughout the truck.
Jul 16, 2010 | MTX Dodge Ram Quad Cab 2002-2003...
I have a 07 GMC Seiarra Classic. The radio has some lights that come on or go off intermittently and the sound comes of and on on some of the speakers. I dont think it is a problem with the speakers...
I have the same problem. Seems when it is dry outside, the radio works pretty good but when the humidity is up, speakers dont work and sounds like treble in the other speakers.
I am to the point as to put a aftermaket radio in the truck.
Mar 22, 2010 | 2007 GMC Sierra 1500
Back surround speakers dont work.
If the display reads 2 chan then that means stereo, and the sound mode is not in any type of surround processing. For your surround speakers to operate you must select a surround sound mode.
Dec 06, 2009 | Audio Players & Recorders
Speakers work,dont work
try a light, clean coating of solder on the ends of the wire strands after you strip them to make the ends like a solid wire. this will give the wire jacks something to bite into.
without further info I would only guess that the tension is weak on the spring loaded buttons or speaker jacks
Dec 12, 2008 | Durabrand 5.1 Surround Sound Computer...
Lights dont work
your speaker working willbe okay
If it not working check the power uspply voltage
some time its due to dry soldering
  • clean the LED leads and resolder it
It may due to LED trouble
  • Replace the LED
Jan 24, 2008 | Sicuro RealWorld 670XL-BK 5.1 Gaming...
LEDs don't light
??????????????? only on fixya would we get a complaint that speakers that are supposed to make sound work great but some lights on them dont work.... ugh.. ok with most of the spealers that have l.e.d.s typically have a seperate connection for the lights. The red wire goes to a switched 12 volt power source, the black goes to chassis ground... if they have power and ground but dont light up then they are junk...
Sep 08, 2007 | Blitz BZX462 Coaxial Car Speaker
Logitech LS11 2 Speakers Logo
239 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
