Question about KitchenAid KGSA906PSS Gas Kitchen Range
OVEN IS NOT WORKING ON KITCHENAID MODEL KGSA906PSS SHOWING ERROR CODE S6:E5
  • KitchenAid Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Oct 05, 2010
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Oven won't heat
You might have to unplug it let it set for a hour then plug it back in and it might set it self.
Dec 31, 2012 | KitchenAid Kitchen Ranges
Error code F3 E5 when using self clean cycle
Error Code F3 - E5 - Oven temperature sensor (RTD) shorted (lower oven, if double oven)
Replace Oven temperature sensor (RTD) or Thermal Fuse.
Hope this helps.
Oct 08, 2011 | KitchenAid Kitchen Ranges
E3F3 on kitchen aId Model KGSS907SSS00 while self cleaning
doorlock will not disingage after self clean cycle is through
Mar 20, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Can't turn oven off
Over the 2008 Hoildays while baking, our Kitchenaid range (KGSA906PSS) "off" button would not turn off the gas oven portion of the range. The two ways we could turn off the oven was to either set a "stop cooking" timer for one minute or to go the main electical breaker box and cut off the electricity to the the range - either way- not a good way. We called Kitchenaid Customer Service at 1-800-334-6889 and stated the problem. We were concerned that this was a safety issue since we could not turn off our gas oven without resorting to the timer or breaker methods. The warranty for the electronics touchpad is from 2-5 years according to our owners manual. We have had the range since Aug. 2005.
We provided our model #, serial#, date of purchase and answered some other questions. Kitchenaid did determine this to be a safety issue and in doing so, our replacement part and labor will be provided free of charge.
Even if your warranty has expired, I would still call Kitchenaid first since this is a safety issue.
Dec 03, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Error Code F5 E5
The repair on this issue will be one of either of these parts.
It is a common issue with Kitchenaid wall ovens.
9759242 THERMAL FUSE/THERMOSTAT/THERMAL T.O.D.
W10175596 THERMAL OVEN FUSE/THERMOSTAT
Sep 05, 2008 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid gas range KGSA906PSS
Google kitchenaid error codes...
I have had three ranges and at least five circuit boards so far... they are garbage, if under warranty, call and complain LOUD.
Jan 17, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
KGSA906PSS
Took me almost three months to get a new range, and kitchenaid still insist it is an "isolated incident"... They need to be exposed and sued...
Aug 17, 2007 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
244 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
