Question about HTC Hero Smartphone
I just got the htc hero and for some reason it says its charging but the battery never gets charged. once i take it off the charger (be it usb, car, or plug), it immediately tell me the phone is dying. Is there a solution to this?
Im having the same problem but im not sure what color the battery water mark because its white but it has these red criss crosses
Posted on Sep 28, 2012
    Guru:
  • 352 Answers
See if there is someone with a Hero and try their battery out. It sounds like your battery is not holding its charge anymore. If you just got it, take it back to the store and see if you can get a replacement.
Good luck.
Posted on Oct 26, 2010
Why won't my Pride Go-Go Elite Traveller batteries charge using a trickle charger? The batteries are new, but my charger quit working.
Hi Robert , can you clarify what you mean by a trickle charger ?, any chance of a photo of the charger ?
using a standard gel battery charger , the charger will charge the batteries in question and once fully charged, the charger will trickle charge the batteries.. This is a standard operation and recommended by battery makers...
Regards
Rob
Jan 09, 2016 | Pride Health & Beauty
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
Phone wont charge
Good Morning My Dear;First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 30, 2012 | HTC Hero Smartphone
HTC Hero won't charge. I bought a new battery...still won't charge. I've tried a wall charger and a car charger and neither of them work.
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
Sep 01, 2011 | HTC Hero Smartphone
My HTC Hero will not charge.
HiTry using another charger if not another battery.
And replace it if one of them is not working.
If none of them is having problems.
Take your htc to a service center.
Good luck.
Aug 24, 2011 | HTC Hero Smartphone
I connect the charger of my htc hero. at first it was charging. after an hour i noticed that it stopped from charging. when i turned on my phone it didn,t open.
Open the back cover , take the battery out . Press and hold the power button without the battery . Put the battery back in . Try to power it on .
If that doesnt work try below steps , ( note : you will loose your data )
Power the device OFF. Press and hold the HOME and Back Arrow buttons. While holding these buttons, press the End Call button once. Release the Home and Back Arrow buttons and press the Trackball to execute the Hard Reset. The device will reboot once the process is complete.
Thumps for my solution if it works .
Aug 15, 2011 | HTC Hero Smartphone
My htc hd2 does not charge or come on? only 9 months old. charger works for other phone.
See if you can try another battery to confirm where the issue lies, it could be anything from a faulty battery to a broken charging socket on the phone...
Feb 10, 2011 | HTC Hero Smartphone
HTC Hero(w/ google, not refurbished) is not charging. If I plug it in, it holds the battery level at whatever level that battery is, and every time i unplug it the battery just gets lower, and never...
If you are plugging it into the usb port of a computer then you may not be getting quite enough power, try plugging it into the wall via the wall charger and see what happens. If nothing happens I suggest taking it into the store you bout it from and letting them see the problem, a lot of them have policies for fixing this sort of situation.
Dec 30, 2010 | HTC Hero Smartphone
Will not charge witg car charger
you'll need to use a usb cord to recharge it once the battery gets to real low. For some reason the car charger won't work. you can plug it in to the usb port on your computer or you can get a car charger that has a usb connection on the end.
Jun 07, 2009 | Garmin StreetPilot c340 GPS Receiver
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
HTC Hero Smartphone Logo
321 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
