Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP 51HW40 Rear Projection tv red flashes
Our tv flashes red and then it shuts itself off. We recently replaced the high voltage part, which seemed to fix it for awhile, but the problem started up again a few days ago. It happens after the tv has been on for awhile. The error code blinks 6 times. Before, it blinked 8 times, which is why we replaced the high voltage part. Please advise. It is getting annoying...
  • 2 more comments
  • dothompson Jun 01, 2008
    Thanks for the info. I think it went over my head, but I'll do some checking. Since I posted this problem, the tv has started blinking 8 times again, as before, and flashing red on the screen, and shutting off. We turned down the red crt, which messed up the colors, and adjusted the colors, etc. on the tv, and it's better than it was, but not great. We haven't had any more flashes on the screen nor shut offs since then. We didn't know how to clear the error code after our first fix, so we don't know if that has anything to do with the number of flashes or not. Could it be that the red CRT is going bad?
  • cftygv Jun 07, 2008
    its the same problem and I was hopping to get some more detailed info.
  • Anonymous Jun 14, 2008
    My KP-51HW40 after warming up (approx 10 min) a red flash apperas on the screen and the TV goes blank. I counted 8 flashes. On turning the TV off and on again the picture resumes but the problem reappears. What do you suggest I do. Will sony repair withour charge, my warranty expired a while ago. Tahnk you
  • AMANDAFIL Dec 09, 2008
    MY TV FLASHES RED AND SHUT DOWN BY ITSELF.SO I PUNCHED MY TV SCREEN AND NOW I NEED TO KNOW HOW TO FIX THE THE FLASHING AND SCREEN...
Thank you very much for the info on clearing the codes. I have a question: what is the flyback? Is that the end of the wire that goes into the HVB that we replaced? When we removed the wires from the HVB, a few of the metal tips broke because we didn't know to push in before twisting and pulling it out. I'm sorry we don't know these terms and parts. We haven't done anything like this before. We were pretty brave to replace the HVB I think...We fixed the tips on the wires by making a new tip out of an end of a fuse, and soldered it. Could that cause this problem?
Posted on Jun 01, 2008
  • Sony Master
  • 8,617 Answers
The +5 line is either shorted or overloaded on the A and B boards that what the 6 blink error code is indicating.
  • Sonny Berry
    Sonny Berry Jun 01, 2008
    I would guess that maybe the solder on the flyback may need to be retouched. The flyback feeds voltages to the CRT heaters and by turning the red crt up your actually increasing voltages to the CRT. I would check the solder on the flyback.
    Heres how you can access the onscreen error display. turn the set off then press in sequence on the remote/
    DISPLAY , Channel 5 , VOL – , POWER
    Then to clear the error code press CH.8 then enter and when your finished press power that leaves the error code display menu.
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
My sony KP-51HW40 TV shuts off
the eight blinks indicates you have a high voltage error. you will need to replace the d board. the part number is A-1348-038-A.
Oct 30, 2007 | Sony KP-51HW40 51" Rear Projection...
I have no picture and the power light flashes green and then red.
I can help you to solve your Sony tv problem.
Is it Sony KP-51HW40 tv or any other model?
How many times red light start blinking after three seconds long pause?
Let me know to proceed, can you check voltages with multimeter in tv circuit board?
Thanks.
Nov 26, 2010 | Sony KP-51HW40 51" Rear Projection...
Picture screen flashes green then the tv shuts off.
have the flyback checked it sounds like its gone bad
Dec 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Oct 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
104 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
