Question about Rule 1800 H53SP-24 Swimming Pool Cover Pump
I have a Rule H53SP-24 pump that runs constantly and never turns off. I understand that this model doesn't use a floater, can this be repaired? Greg
4 Suggested Answers
SOURCE: Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Posted on Apr 19, 2009
SOURCE: broken garden hose adaptor
We have the same pump and problems. I have attempted a few fixes with PVC sealant and hose clamps to the current adaptor, however the adapter is still continuing to crack. The adapter is removable- carefully so as to not damage the small eyelet it attaches to, (or in our case, it came off on it's own) and can be replaced by any adapter that fits- they can be found all over at lowes or home depot. I am personally going to try using a broken hose and clamping it directly to the eyelet. This is not a good reason to buy a new pump- they fix too easy!
Posted on May 07, 2009
  • 10865 Answers
SOURCE: I have a Rule 1800 H53SP-24 Swimming Pool Cover
Hello. There are several possible issues here which are all fairly easy to investigate. Begin by bringing your pump, cord and hose into a warm space for 24 hours to thaw everything out, warm it up and dry it out. Then try it. If it works, you know you have one of the problems described below:
1. Sometimes a circuit breaker wears out and needs to be replaced. Try your pump on a different circuit, insuring that you are using a different circuit breaker. IF it works there, the solution is to replace that worn circuit breaker. 2. Check the impeller and remove any clog, blockage, debris or residue. 3. The 24 foot cord on your pump might have a cut, or a scrape on it. If it does, water is getting into the insulation and causing the circuit breaker to kick. Check your cord thoroughly and if you do have a break in it replace the cord or repair it with a waterproof repair. 4. Your pump motor may be worn or faulty or have a water intrusion. In that case the only fix is to replace the pump. 5. The drain hose could be frozen. If it is, that blockage could cause the breaker to kick. Always ensure that the hose runs consistently downhill.
If you would like to contact Rule, you may do so at the following link: http://www.rule-industries.com/
Regards, Joe. Please rate my answer. Thank you and happy holidays.
Posted on Dec 26, 2009
Why would my Rule pump, model H53SP-24, continue running after the water has drained?
because it doesnt know or care if there is water in it. there is no flow sensor to cut the electrical supply. these pumps are either on or off.
Aug 20, 2014 | Rule Pool & Spa
The third prong on the cord broke off ,,, can I still use
Yes it matters. You can buy a 20 amp 3 prong from Lowes and re wire.
Nov 08, 2012 | Rule 1800 H53SP-24 Swimming Pool Cover...
Trips GFCI outlets
The motor on this unit is sealed and not accessible for repair, only replacement.
Mar 09, 2010 | Rule 1800 H53SP-24 Swimming Pool Cover...
I have a Rule 1800 H53SP-24 Swimming Pool Cover Pump. Everytime I plug it in it trips the breaker. Did not have this problem with the same pump a month ago. Tried in GFI and all other outlets. Any...
Dec 26, 2009 | Rule 1800 H53SP-24 Swimming Pool Cover...
Rule 1800 H53SP-24 Swimming Pool Cover Pump Logo
Top Rule Pool & Spa Experts
Bill Jordan
Robco Water
Robco Water
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
