Question about Nixon OUTSIDER WATCH
When light button is pressed numbers fade on watch face
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    Accutime batman watch time setting
    if it is the Batman watch that has a secret screen that lights up when you pushed the bottom middle of the watch face this is what worked for me.I call that secret middle button the mode button.
    push and hold that secret button on the watch face until the hour side of the time starts to blink. let go when you see the hour blink and then you can keep pressing to change the hour. to change the minute I let it go back into sleep mode then press and hold the secret button on the watch face and when it starts to blink let go for half a second and then press down and hold that button again and a minute numbers should start blinking. when they start blinking let go and then push once for each minute. it seems once you start one of these cycles letting go for half a second and then pressing and holding the mode button works. you'll have to experiment with how long to let go and then push.
    Apr 03, 2013 | Watches
    My digits are dimming or fading making the watch hard to read. Battery reading is "high"
    mcdevito75 Here, The battery could be loose makeing a weak connection or the LCD screen could be going bad, Have a small watch repair shop in your area check it out. If you can do so yourself be very carefull as too much pressure on the battery (PRESSING) could destroy the LCD face of the watch, also if the display (FACE) of your Casio ever goes black, even if display returns, the LCD is going bad.
    Feb 05, 2011 | Casio G-Shock GW700A-1V Wrist Watch
    How do I set the time on an Adidas calculator adh4020 watch?
    p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial; min-height: 15.0px} p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px} p.p4 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p5 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Helvetica} p.p6 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Helvetica; min-height: 16.0px} span.s1 {letter-spacing: 0.0px} span.s2 {font: 12.0px Helvetica; letter-spacing: 0.0px} span.s3 {font: 13.0px Arial; letter-spacing: 0.0px}
    I have the Adidas ADH4018 and I assume the controls are the same, unfortunately, Adidas has absolutely no manual online for this watch. I've figured out how to do most of the functions of this watch.
    NOTE: For greater setting accuracy, I recommend using a stylus-like object or the retracted tip of a retractable pen (as to not write on your watch) to click the number keys when setting the time and date for the first time.
    Set the Time:
    To set the time go into time mode by pressing the lower silver button on the right side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 7 to change the hour, press the number 8 to change the minutes, press the number 9 to start the seconds over at 00. Press the multiplication key (x) to change from 12 hour to 24 hour time modes. When finished press the time mode key.
    Set the Date:
    To set the date go to time mode by pressing the lower silver button on the left side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 4 to change the month number. Press the number 5 to change the day of the month. Press the number 6 to change the day of the week (indicated by a small dot above the days of the week abbreviations at the bottom of the digital display. When finished, press the time mode key.
    Set the Alarm:
    To set the alarm time, enter alarm mode by pressing the upper silver button on the right side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 7 to change the hour, press the number 8 to change the minutes. When finished press the time mode key.
    Turn the Alarm On or Off:
    To turn the alarm on or off, first enter alarm mode by pressing the upper silver button on the right side of the watch face. Then press the divide key (÷) to change from on to off or off to on. When the alarm is ON an indicator icon will appear in the upper right of the display in time, date, or alarm mode. When alarm is OFF there will be no indicator icon displayed.
    To Use the Calculator Function:
    Enter Calculator mode by pressing the Clear All (AC) key on the keypad when in time mode. Use the number keys and function keys to complete calculations. To return to time mode simply press the time mode key.
    As of yet I have not discovered how to turn off the annoying beep when you press any button.
    Oct 26, 2010 | Watches
    I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
    Thank you for contacting FixYa.
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    I bought a ladies armitron watch.. and can't reset time.. day etc is fine.. the symbols left hand side say 'set' 'mode' right hand side 'ADJ' 'AL' ... can you help.. Thanks Leanne
  • Look at your watch as if it were a clock face, even though it may be a digital. Most Armitron watches have four buttons around the perimeter of the watch. There will be a button at the 2 o'clock position; this will be button "A." There will also be a button at the 4 o'clock position. Consider this button "B." On the opposite side will be button "C" at the 8 o'clock position and button "D" at 10 o'clock.
  • Press the "D" button until the numbers begin to flash on your digital watch. Press and hold the "D" button again until the seconds begin to flash by themselves. Press the "B" button to advance the seconds. You may hold down the button in order to cycle through the numbers faster.
  • Hold down the "A" button in order to move on to setting the Armitron minutes. Once they begin flashing, press the "B" button just like you did to adjust the seconds. Press the "A" button one more time, and you will see the hours flash on your watch face. Hold down the "B" button and cycle through, making sure the a.m. and p.m. is correct.
  • Change the date on your Armitron watch by once again pressing the "A" button. This should cause your date to blink. Press the "B" button to change the days.
  • Cycle through the months by pressing the "A" button one final time and holding down the "B" button.
  • Aug 27, 2010 | Armitron Watches
    I don't know how to turn off the automatic light feature on my watch
    There is a button with an atomic time symbol below the face of the watch. Press and hold this button until you hear a beep and the light will go off. To turn it back on again, just press and hold that same button until you hear a beep and it will come back in automatically when you tilt your watch.
    Oct 15, 2009 | Casio G-Shock GW500A-1V Wrist Watch
    TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
    ANALOG TIME
    Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
    Oct 27, 2008 | Timex Watches
    Columbia Watch CL-5030
    Hold the light button (top left hand) for a few seconds and the adjustment mode becomes available.
    Dec 25, 2007 | Columbia All Sport Digital watch
    Stumped
    Try to use a piece of tape to cover on the battery, this is a way to do the insulation to prevent bad contact.
    Tsai
    Jun 19, 2007 | Kenneth Cole Reaction Square Steel Case...
    Nixon OUTSIDER WATCH Logo
    157 people viewed this question
    Top Nixon Watches Experts
    Ansel Alberto
    Ansel Alberto
    rhodesworks
    Are you a Nixon Watch Expert? Answer questions, earn points and help others
