Question about BenQ DC E30 Digital Camera
Carte mémoire compatible - BenQ DC E30 Digital Camera
  • felixlaurenc Oct 05, 2010
    est-ce que les cartess memoire sony SD HC 4GB sont compatible avec mon appareil photo
    Brigadier General:
  • 3,006 Answers
Sorry my answer is in English, je ne parle pas tr?s bien le Fran?ais. Hopefully you can read English or can get this translated.
First check that you are using an SD card with a capacity which does not exceed 2GB as that is the maximum your camera can handle and it will give error messages with larger capacities, especially if you have fitted a later specification SDHC card.
If you are using the correct type and capacity of memory card then this is such a common question that I hope you don't mind if I paste my generic answer below. Note that cards may appear to be unlocked when they're not. The answer also covers what to do if the card is faulty.
Your camera uses SD memory cards. On one edge is a slider switch: towards the electrical contacts is the unlocked position and away from them is locked.
Unfortunately, the switch is easy to move accidentally and it's also easy for it to appear to be unlocked when it isn't. Like any mechanical component it's also possible for the switch to fail.
If the switch is in the locked position then slide it fully to the unlocked position; if it's already in the unlocked position, slide it fully to the locked position and then fully back again. There should be a soft click at each end of the switch travel, if not then the switch is definitely faulty or obstructed.
If that fails, then try looking closely at the switch in both positions to ensure that there is no debris obstructing its movement, if not then check the electrical contacts to ensure that they're completely clean and grease-free. Don't touch the contacts with your bare skin, but if the contacts need cleaning then a cotton bud (Q-tip) moistened with a little alcohol or methylated spirits can be used to clean them.
If you still have no fix, then try a different SD card as yours may have an irreparable faulty switch. If the card does prove to be faulty then on most major brands you may be able to return them to the manufacturer for exchange: I've found that they will often do this on a goodwill basis even if the card is out of warranty. Just check the manufacturer's website for support details.
If all options regarding the memory card are unsuccessful, then you have a faulty camera and further remedies require either a professional repair or replacement of the camera.
I hope that my free answer has been of use and has given you options to fix your problem. Please let me know by taking a brief moment to rate my reply.
Posted on Oct 05, 2010
  • Obertelli
    Obertelli Oct 05, 2010
    Your rating of my answer is very unfair. Your camera does not accept SDHC cards!
    Votre note de ma réponse est très injuste. Votre appareil photo n'accepte pas les cartes SDHC!
Impossible de prendre des photos avec mon appareil KODAK Easy Share C182 Dgital Camera. J'ai le message suivant qui s'affiche : "La carte mémoire est...
Before the camera will take pictures, it's necessary that the 'commutateur' on the card operates a switch in the camera, which it should do if it's in the 'unlock' position. If you've already checked that, it must mean that the 'commutateur' isn't quite thick enough to operate it properly, or that the switch in the camera is broken, or that the tiny lever has broken off when you put a card in. I would definitely try a different card (of a different brand (marque)) to see if small differences in thickness are the problem.
Jan 20, 2011 | Kodak Easyshare C182 12MP Digital Camera
L'appareil model # PB 80 Il ne lit pas la carte mémoire sdhc Peut-on ajouter un appareil qui lui permetterait de lire ces cartes mémoires merci ghislaine.sauvageau@videotron.ca
The SmartDisk PhotoBank will not read cards above certain capacities (depending on the type of card). For example they will not read SDHC's etc.
If it won't read any cards (and it use to) then you may have a problem with your driver as I had such a problem. If this is the case please see below. (N.B. always best to back-up and/or create a restore point before updating drivers etc.)
This solved my related problem...and it may solve yours...please let me know if it does...
I had a similar problem (probably caused by deleting files within the device folders on my PC) and have searched tirelessly for a solution and had pretty much given up until I stumbled upon a link to the site below.
http://www.box.net/shared/i8dknblsuy#/shared/i8dknblsuy/1/25549066/265225700/1
SmartDisk_FAT32_tool.exe (392.0KB).
(Sorry don't know how or indeed if 'allowed' to attach files etc.)
I was dubious at first with so many previous false dawns and especially with concerns about security. Although I can't personally vouch for the site, the link or the downloads integrity, McAfee gave the site and links a 'green' bill of health, the laptop is still functioning fine and as it should (nothing malicious detected by various security software such as McAfee and Spybot S&D etc and most importantly the SmartDisk PhotoBank is once again fully operational; all in an instant with no ill-effects or anything untoward occurring.
KR
DIMDIY
Jan 10, 2011 | SmartDisk PhotoBank USB Digital Dr 80 GB...
J'ai un appareil photo vivitar vivicam 6150s
get the manual at http://manualfox.com/link/vivitar.htm
Mar 14, 2010 | Vivitar ViviCam 6150s Digital Camera
J'ai un canon ir1600 & j'ai un prblm avec l'erreur ysteme e100
E100 Quand le moteur de module de balayage est mis en marche, le signal d'entrée du BD n'arrive pas au cours d'une période spécifique. Quand le moteur de module de balayage est mis en marche, la rotation de moteur est trop rapide, et échouer pour atteindre une révolution spécifique à moins de sec 20 à la période de la décélération. Tandis que le moteur de module de balayage tourne à une vitesse spécifique, le signal d'entrée du BD le cycle n'est pas dans une marge spécifique (±2%) pour un équivalent de 10 millimètres (distance d'impression). Tandis que le moteur de module de balayage tourne à une vitesse spécifique, le signal d'entrée du BD le cycle n'est pas comme indiqué (±2%). Au cours de la période de WMUPR après que le commutateur électrique ait été mis en marche ou la couverture/couverture gauche a été ouverte/fermée, l'unité à tambour est absente. La cause possible le câblage est défectueuse (court-circuit, circuit ouvert). L'unité de module de balayage à laser est défectueuse. La carte de contrôleur de C.C est défectueuse. L'unité à tambour n'est pas installée. Remède 1) Unité à tambour L'unité à tambour est-elle installée dans l'ordinateur central ? NON : Installez l'unité à tambour. 2) Raccordement Est le raccordement du connecteur (J908) sur la détection du BD Carte, connecteur (J907) de l'unité de laser, et connecteur (J102) dessus la normale de carte de contrôleur de C.C ? NON : Corrigez le raccordement. 3) Unité de laser/module de balayage, carte de contrôleur de C.C Essai remplaçant l'unité de laser/module de balayage. Le défaut est-il corrigé ? OUI : Extrémité. NON : Remplacez la carte de contrôleur de C.C. Vous aurez besoin d'un manuel, vous pouvez obtenir un ici http://www.techmanualarchives.com/canon-ir1600_1610_2000_2010-service-amp-parts--manual-25158.html
Feb 23, 2010 | Canon ImageRunner 1600 Copier
Comment faire pour Déverrouiller la carte sd
take card out. a switch on the side of the card.
Sortir la carte. un commutateur sur le côté de la carte.
Nov 26, 2009 | Jazz DV-179 Digital Camera
Je veux savoir les caracteristiques de mon pc
Merci pour votre demande.
Voila les details demander
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} desktop
i
OLIVETTI OLIVETTI
OLIVETTI DESKTOP AD200N-1245 OLIVETTI DESKTOP AD200N-1245
Processeur Intel® Pentium® Dual Core E2180 (2x 2.00 GHz, 1 Mo L2 cache), Chipset VIA® PM900, Mémoire DDR2 1024 Mo, Disque Dur SATA 160 Go Intel ® Pentium ® Dual Core E2180 (2x 2.00 GHz, 1 MB L2 cache) Chipset VIA ® PM900, DDR2 1024MB, HDD 160GB SATA
Prix public : 6100DHS Retail price: 6100DHS
OLIVETTI DESKTOP AD200N-1210 OLIVETTI DESKTOP AD200N-1210 Processeur Intel® Celeron® 420 (Core 1.60 GHz, 512 Ko L2 cache), Chipset VIA® PM900, Mémoire DDR2 512 Mo, Disque Dur ATA 80 Go Intel ® Celeron ® 420 (Core 1.60 GHz, 512 KB L2 cache) Chipset VIA ® PM900, DDR2 512MB, HDD 80GB ATA
Oct 19, 2009 | Computers & Internet
Saab 9-3 trip computer SID with only partial display, fixable?
TRY THIS: http://www.saab9-5.com/howto/sidrepair.htm
That shows Step by Step info how to do it, and it looks promising, Im going to try that on my 9-5 Trip computer and Im sure the 9-3 has the same since Saab models from 1998 - 2003 have the same common problem, save yourself the money on a refurbished one, I got quoted $300 for a new one, why bother if I can fix it myself, and if I scew it up, then buy a refurb one,
Jan 25, 2009 | 2000 Saab 9-3 Viggen
BenQ DC E30 Digital Camera Logo
Top BenQ Cameras Experts
Tony
Edward Talavera
Edward Talavera
Are you a BenQ Camera Expert? Answer questions, earn points and help others
