Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Will not turn on blinks 9 times then 5 times
All of the sudden the tv will not turn on. blinks 9 times then pause blinks 5 times. any suggestions?
  • 1 more comment
  • kadnpgf Jun 01, 2008
    where is the deflection board?
  • kadnpgf Jun 09, 2008
    thank you for your help. we havent tried it yet, but we plan to as soon as we have time. the repair shop said it was the high voltage transformer, but that was over the phone. we plan to try the hair dryer first. will let you know if it works.
If you open up the back panel,like 8 screws,you will see 2 circuit boards exposed.the deflection board is the left 1.the other 1 is on the right side is the processor board.if using the hair dryer to warm up the left board doesnt help,try heating up the right board.only a couple of minutes may be needed if temp is the issue,i know my problem,works every time.i have to do this every time to get my tv to start up.for me its worth the trouble then to trash this big tv or spending tons of money to fix this obsolete tv.good luck.
Posted on Jun 01, 2008
Heat the deflection board with a hair dryer 1-2 min before turning on tv
Posted on May 31, 2008
  • elles3 May 31, 2008
    that blinking is a test code failure number 95
I have Sony Bravia model KDL-55NX720 & it won't turn on.It has 5 blinking red lights.According to a diagram that I found for this TV, I have replaced the TCon Board and the LED Panel. Any suggestions?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 14, 2016 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red light blinking
You have a bad main board most likely. You can try unpluging it for 5 minutes.
Sep 03, 2009 | Philips 42PF9631D 42 in. Plasma Television
Sony Trinitron---Blinks 9 times, won't come on!
A specific model number will probably get you more specific
help.. but if you check around the internet by model number
you will likely be presented with some SERIOUS PART opportunities...
The FASHING LIGHT means you have a hard fault in the power circuits...
The number of flashes is mean to point you to a specific area...
I gave all my big flat screens away in favor of the new
HD stuff... (certainly less reliable than those Sony sers...
Shopjimmy might be a great place to call... but the MODEL NUMBER is a MUST.
TV Parts Universal TV Stands DLP Chips ShopJimmy
May 18, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Cannot turn tv on!
hello, you do have a horrizontal problem, you may have a short parts on the said section, shorted horrizontal output transistor can couse this indicator to blink. when a shorted transistor then you may have a defective FBT. try to check some parts. ty
Dec 21, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
253 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
