Question about Stoves 720EF Electric Double Oven
I have a stoves q720 em do oven and need help how to use the timer as when i try it keeps turning itself off
4 Suggested Answers
  • 883 Answers
SOURCE: My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
Posted on May 24, 2007
  • 62 Answers
SOURCE: oven shuts off by itself
Hello
I am also having the same problem http://tvtropes.org/pmwiki/pmwiki.php/Main/IReadThatAs
this is going to help you
Thanks & Regards
Posted on May 23, 2009
SOURCE: My Stoves 720EF Heritage oven keeps turning itself
does anyone know were i can get a replacement top oven inner glass for my stoves heritage 720EF ?
Posted on Sep 11, 2011
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
STOVES 900GDO USER MANUAL NEEDED
Good luck, and im being sincere, unless you find someone with exact stove to help you i didnt see a single thing for a manual online.
If you can make the timer function, a standard digital timer can have up to 4 numbers.. and when you punch in numbers it goes from right to left.. my stove for instance.. the very first number is minutes. so even if it says 0005, that could be 5 minutes not seconds, and my oven, you dont press anything to start timer, you just put it to required minutes and it starts itself lol.......maybe this provided some insight?
Nov 01, 2013 | Ovens
Stoves 720ef small 'A' appears left of display. how do i get rid of this and return to manual? without fiddling cannot turn oven on. I have no manual
If the 'A' appears, it means that the automatic setting has been enabled. To stop this and return to manual setting, press the COOK TIME and READY TIME buttons simultaneously.
The COOK TIME button is the second from the left and the READY TIME is the third from the left.
If the 'A' keep s reappearing by itself, then it could mean that the timer is going faulty. ESPARES should be able to supply one.
May 29, 2011 | Stoves 720EF Electric Double Oven
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
Need instruction manual for stoves heritage 720EF cooker
Supply an email address and I will validate it on my BT Digital Vault to give you access to take a copy of the Handbook.
Nov 03, 2009 | Stoves 720EF Electric Double Oven
Oven shuts off by itself
Hello
Thanks & Regards
May 23, 2009 | Ovens
STOVES 720ef Oven Programme won't go off automatic
This is a solution - of sorts - but probably not the one that you were hoping for.
My Stoves 720EF oven developed the same fault.
I tried pressing the buttons in various combinations and I tried switching the power off and on, restting the timer and the clock, no joy.
I then tried getting hold of a copy of the manual and trying to fix it, no joy. Called up Stoves and booked a visit from a specialist service engineer, costing £75 +VAT for the call out, and was advised that the engineer would attempt to repair it but it might need a replacement circuit board, costing a further £110 plus VAT.
engineer arrived on the appointed day and was straight onto swapping out the circuit board - not much scope for "attempt to repair" - so that was about £190 plus VAT to fix it. job took about 25 mins and didnt seem to need anything beyond what any electrician (or electrically-expert DIYer) could do.
comes with a 12 month warranty - hopefully it will work without any issues !
If you have a regular electrician you might prefer to buy the board and get your electrician to do the job - or do it yourself, assuming that you are suitably skilled and qualified.
hope this helps
cheers
David
Nov 07, 2008 | Stoves 720EF Electric Double Oven
May 24, 2007 | De Dietrich UMP404 Powerclean Stainless...
Stoves 720EF Electric Double Oven Logo
59 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
