Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips dptv335 rear projection tv DVI hookups
Im coureous to know is the Philips dptv335 compatible with projection from a compter using DVI cables in the DVI imput in the rear of the Tv? I bought a DVI to VGA connection cord and it wont work. If it is compatible will you tell me what I might be doing wrong? Thanks
ctf1800
  • 4402 Answers
SOURCE: philips rear projection tv 43pp8545 no picture sound ok
do you get a blinking read light?
Posted on Dec 14, 2007
SOURCE: cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
  1. Remove the screws from the ventilated back panel (the piece of wood with a bunch of holes in it surrounding the AV connection panel.
  2. Remove the wood panel you just unscrewed.
  3. Remove all screws from the upper plastic case on the back.
  4. Remove the back plastic case carefully. This is a little tricky due to two metal pins that it hangs on. Lift it upwards and you should be able to free it from these pins
  5. At this point you should be able to see the entire workings of the TV, and consequently the massive amount of dust that has accumulated.
  6. Carefully take a vacuum and remove all the cobwebs, taking care not to bump the mirror or the lenses.
  7. First, I used some compressed air to clean off the lenses and then used a clean microfiber towel to remove all the dust from the lenses, the mirror, and the screen on the inside. Make sure the part you are wiping the mirror and lenses off with is free from any dust or dirt or you will risk scratching them.
  8. Reverse the dissasembly process to put the case back together.
  9. I went through the convergance settings at this point and found that they were all out of calibration and as such recalibrated them. Use the mulitpoint calibration for best results.
  10. Enjoy a much cleaner brighter TV!
Posted on Mar 25, 2009
falsafat
  • 31 Answers
SOURCE: Connect Sony Vaio Laptop to DVI on Sony LCD Projection TV
try to lower the resolution of the display, to know how please visit the following link:
https://www.microsoft.com/windowsxp/using/accessibility/screenresolution.mspx
< Please Rate :) >
Posted on Apr 12, 2009
mjbarton74
  • 6 Answers
SOURCE: Watch movies from computer to tv
look on the back or sides of the unit. it should have a hdmi cable hookup, it will look like a monitor input, then you have to make sure you set the tv input to that. then you have to set your laptop to add another monitor to be able to use it.
Posted on Apr 28, 2009
SD Tech
  • 14553 Answers
SOURCE: convergence point problem on a Philips TV
The 55pp9352 model number uses 2 of the STK-392-120 convergence chips--if it will not adjust in some direction--both chips and any of the 6.8 ohm resistors around them that are bad need to be replaced.
The reason this happens is the chips are about 2 1/2 inches wide X 1 1/2 inches tall with a metal back--they are attached to separate metal heat sinks and a white grease is applied to each to transfer heat quickly---after several years the heat sink grease dries out and one of the chips cannot stay cool enough and fails.
Pretty common problem in ALL rear projection sets--if model is 55pp, it is 55 inch set.
You can buy the chips on Ebay for less than 12 dollars---the resistors if needed are cheap parts.
It depends if you are able to do the repair yourself or need to have someone do it for you--most shops get at least 300 for this kind of repair--considering the parts cost less than 20 dollars if you can do it yourself you can save a lot of money.
Any good tech can do this repair in your home in about 1 hour--I know as I have done hundreds of them.
If you need help or advice let me know--I am here to help people.
Regards, SD TECH
Posted on Oct 11, 2009
Philips projection dvi problem
The set is old enough (based on model number indicated here) the DVI input (supprised it has one) it will not work with newer equipment.
Apr 15, 2012 | Philips 55PW9363 55" Rear Projection...
Im looking for a projection alighment chip for 60pp9202/17f phillips
you will require two of the STK392-120 Convergence ICs and possibly the 6.8 ohm resistors. The Phillips DPTV305 - DPTV335 convergence repair kit available from www.tvrepairworld.com has the two ICs and the 12 resistors plus the CD with repair instructions.
Sep 25, 2011 | Philips 60PP9202 60" Rear Projection...
55" Philips rear projection HDTV..
that input is called DVI digital video interface it is only for video. there should be some red and white composite input jacks for the audio near the DVI connector. you will need to hookup the red and white cables from the tv to the cable box or dvd player or whatver you are using. good luck
Jan 06, 2011 | Philips 55PW9363 55" Rear Projection...
We have a 2003 60inch? hdtv tv dptv335 the sound works but our picture went out 2 days ago while we were watching. no load noice or bright light..just went black. what do we do? kris
The tv had not been change the projection lamp the last 1 1/2 or 2 years and on used like 4 or 5 hours day.The tv pojection lamp life is over.Replaced a new tv projection lamp.
Sep 15, 2010 | Philips 55PW9363 55" Rear Projection...
What HDMI to DVI-D cable will work with Philips 60PP9352 60 in. Rear Projection Television? Please help. I've looked everywhere and can't seem to find one.
Get an HDMI to DVI adaptor and use a generic HDMI cable.
Lots of DVI MALE to HDMI FEMALE adaptors out there:
Ultralink, Monoprice, Monster etc.
Jan 01, 2010 | Philips 60PP9352 60" Rear Projection...
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Mar 20, 2009 | Philips 55PW9363 55" Rear Projection...
Philips DPTV335 Tripping
Even if you find the problem you most likely can't buy the parts, this TV type is obsolete.
May 01, 2017 | Philips 55PW9363 55" Rear Projection...
Dvi hooked to hdmi
DVI cable is only video you will need to hookup some standard red and white audio cables in addition to the DVI
Apr 10, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
