Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
No Video Display, TV is Black. Have all audio and remote functions
Model 60PP9202/17F
  • Philips Master
  • 3,459 Answers
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
Posted on Jun 29, 2008
Samsung tv mute button is not cancelling tried to get volume back but cant get any sound
  1. On the TV remote, find and press the Menu button to enter the display for audio and video settings on the TV screen. ...
  2. Locate the Audio menu to turn the speakers on or off and select "on"
  3. Select "Fixed" in the Audio out section of the setup menu if available.
If this does not work add the model number to your post.
Sep 25, 2017 | Samsung Televison & Video
TV Problem: No Video but Audio works
Here are some basic treatment for a dark display.
  1. On LCD TV, Some time missing or lose LCD strip from PCB connector. Solution- Clean strip and connector.
  2. Some time missing LAMP, burning lamp is a major cause for dark display in LCD TV. If lamp problem with any display, Display show in sun lights. Solution- Check Lamp connection/connector. Clean connector or change Lamp.
  3. In CRT TV, Fly back is faulted. There are no high voltages. Solution- Change or check fly back, Check out put transistor.
  4. Some OLED Tv Use OLED lights for display shining and brightness. IF LED's or lamps are faulted there is no display in sun shine.
  5. Before starting Troubleshoot display problem you need to conform and trace faulted stage of TV.
  6. Don't Apply any miss use trick at home. Contact the professional repairing lab.
  7. If you are full fault to understand your TV problem. Tip more condition of your problem.
Jul 02, 2015 | Element Televison & Video
No picture, just sound on Etec Flat Panel 40A99
Video circuit is separate from the Audio circuit. The main controller may switch to Audio, but if the unit is damaged from a power outage; part of the circuit board may not function. Needs professional servicing.
Feb 26, 2014 | Cars & Trucks
Need directions on how to hook system up to tv
Check the back of the system, you will find Video out, then Audio out (left and right). Connect the yellow cord to video out, and the white & red to Audio out appropriately.
Then connect the other end of the yellow cord to "Video in" at the back of the TV, then the red and white to audio in at the back of the TV.
After connecting as directed above, turn on the TV, then turn on the system. On the TV remote control, press "AV" or "Source" depending on what is written on the remote and there should be a display. If there is no display, press the "AV" or "Source" on the remote once or twice more and there should be a display of the receiver's welcome screen on the TV. You might also need to press "Source" on the system's remote if there no display.
Let me know if you don't av display even after following the above steps. The above is the correct way of connecting so it should work.
Note; The White and Red cords stands for Audio left and right, while the yellow cord stands for Video. The yellow is suppose to allow your system display on the TV screen, while the Red and White is to bring out sound.
I hope the above helps.
Good luck.
Feb 01, 2011 | Audio Players & Recorders
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Jan 27, 2011 | Apex Digital AT2702 27" TV
Display doesn't light up on Onkyo TX-DS595 reciever
try to connect the receiver to a tv via the monitor out from the receiver to the tv. you may be able to see the OSD (on screen display of your settings) change the function on that to turn on the front display. alternatively look on your remote to see if you can turn up the light of the front display.
if these don't work possible that the light of the display has blown
Dec 04, 2010 | Onkyo TX-DS595 Receiver
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
Blank display on a Onkyo TX-SR501
if these don't work possible that the light of the display has blown.
good luck
smeags.
Dec 31, 2007 | Onkyo TX-SR501 Receiver
Accidently locked tv
gonk,
Sorry but you're going to have to be a bit more specific than that.. What kind of Tv is it, what model number, is it the original remote, do you have an otherwise good pic and sound, do functions (vol, ch, power) on the Tv work???
Bill
Dec 11, 2007 | RCA 20F514TD 20" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
