Question about Jl Audio 13W7 Car Subwoofer
Popping I have a 1000/1 and a 13w7 i just installed brand new out of the box. I wired the sub in parallel as it should be. I ensured both coils were hooked up. And when I turn the stereo up the sub pops. I lowered the level of the amp from 3/4's gain to 1/2 and still popped. The Sub was barely moving. No distortion. I just can't believe I would have been given a faulty sub from JL. They always check their products. I bought a box that was built to ported specs. Because I know the air space in a box can cause it to "bottom out" or whatever and sometimes cause it to pop. Even with that box being built to specs can the way the air space is formed make a difference? I took the sub out of the box and turned it on and it popped even with it turned down very low. Even if i tilted the sub so that it was not flat against a surface. I would just like to know some things that might cause that and maybe get someone who is more knowledgeable on the actual internal functions of the sub to give me their opinion.
  • 2 more comments
  • liddon21 Jun 04, 2008
    Mate i had the same problem, Went to the local audio shop and they said it should be run is series.
    Since re-wiring the sub its been great can crank it up till me battery goes flat and no popping at all.
  • earp Jun 12, 2008
    Actually.. the subwoofer popped because there was not enough voltage.. the popping came from the amp producing a mechanical "error".. added a second battery fixed that.. a bigger alternator would be the smart and better way to go.. but im not droppin another 500 bucks..  the low ohms i did fix on my own.. no thanks to the idiots at the local audio stores.. i wanted to wire the sub in series.. they told me to wire it in parallel.. and i questioned it and said that would be too low.. and they argued so i did it their way since they are supposed to be "professionals" and i just do it for a hobby.. but whatever.. wired it in series and works jus fine.. the idiot tried saying wiring a dual 1.5 ohm sub wired in series would be running 6 ohms.. yeah.. no.. 3 ohms.. i think someone should find a new career..
  • paula1988 Jul 28, 2008
    my j;l pops when i turn it up is it becuse it its new and breaking it in? i have 2 jl 13w7 and 2 100 jl amps... the amp is not turned on that high the guy at the audio store told me that it was because they were knew .. what is your guys advice
  • EMA12 Mar 11, 2009
    i got the same problem but i got 2 12 w6 and a 500/1 jl amp hooked up.
If you Wire the 13 w7 in parallel you get 0.75 ohms which this amp is incapable of handling, that's why your speaker is popping. Be carefull cause this setup could ruin both your amp and sub. You have to wire that sub in series so that the amp "sees" a 3 ohm load which it's best suited for.
Posted on Jun 11, 2008
^^^He's right...the 13W7 is supposed to be wired in series to get 3 ohm load.
Posted on Oct 11, 2008
3 Suggested Answers
  • 578 Answers
SOURCE: JL Audio 13w7 & 1000/1 Amp Settings
that depend on how you wire the speaker my friend and the performance of you am and u have to use jl -dclass series amp for the best performance of those speakers
Posted on Aug 07, 2009
  • 129 Answers
SOURCE: JL 13w7 & 1000/1 Settings
There is no "perfect" setting that can be placed in a manual. It's all done by ear. Your settings will vary depending on the vehicle you are in, the type of enclosure you have, the type of music you listen too, how much voltage your deck put's out. There are many variables, but I can try to give you a basic guide.
First of all you need to know your enclosure. If you have a ported enclosure tuned in the mid to low 30's you may want to set the low pass to around 70-80 hz with your sub sonic set at 30 hz. this will give you the higher bass frequency you need for the loud bass you want, and protect the sub from going too far below the tuned frequency of the enclosure, and losing it's composure.
As far as the gain, and bass boost are concerned, you just have to adjust them by ear. First adjust the radio volume to normal listening levels, by that I mean as loud as it can go without the speakers in the car sounding like ****. Now you adjust the gain first. slow turn the gain control, carefuly watching and listening to the sub.. Adjust the gain to the point of the woofer getting a lil sloppy then back it down a bit until the sound is clean again. Now do the same with the bass boost. if there is a bass boost frequency adjustment, set that as close to the tuned frequency of the box as you can.
If you are in a sealed box the adjustments are a bit easier, and are all about taste. Adjust the radio as described before, and put on your favorite song. Next start udjust thing lowpass frequency to taste, not too high tho, try not us higher than 100 hz in your sub's for better sound. Sub sonic is not quite as important in a sealed box, as there is much less danger of the sub losing control.
Well good luck, and hope this helps!
Posted on Aug 08, 2009
How do i wire alpine swr1243d subwoofer
There are a couple different ways you can wire up this speaker as it is a DVC speaker. Duel Voice coil, it has two + post and two - post. A dual 4-ohm voice coil subwoofer with its coils wired in parallel presents a 2-ohm load to your amplifier. Since an amplifier produces more wattage at a lower impedance, the parallel connection ensures you'll get the most output from your amp.
Series wiring lets you configure multiple woofers to one amplifier at an acceptable impedance. Wire both coils in series for an 8-ohm impedance, and then wire two 8-ohm subs together in parallel for 4-ohm total impedance.
You can wire each voice coil to a separate channel of your amplifier, if you prefer not to bridge your amp. Independent wiring is a nice option if you're wiring two DVC subs to a 4-channel amplifier - one voice coil per channel
Depending on what you are hooking it up to i.e. a mono amp or a bridged four channel amp. I can tell you post to wire exactly if I know how you want to hook it up and what ur hooking it up to.
Sep 15, 2014 | Car Audio & Video
Wire 2 sub 4ohm
I am assuming these are subs, you didnt say, but that is my guess. do you want bass, or do you want to take it easy on your amp? do you have a terminal cup on your sub box, or just wires going into the box to the speakers? take it easy route: wire positive from amp to positive of one speaker, negative of amp to negative of the other speaker, with a jumper wire connecting the negative of the first speaker, to the positive of the second.
more bass route: run seperate positive and negative wires to each speaker, making sure to maintain proper polarity.
Oct 21, 2013 | Jl Audio 500/1 Car Audio Amplifier
I got these subs given to me brand new from my dad and was not sure on how to wire the duel voice coils. Could you please tell me the different ways to wire the coils for the different ohms. Thanks, Gerald
Ok..If each coil is say 4 ohms and you wire them in parallel you will obtain 2 series you will obtain 8 ohms...remember..series resistors add together and parallel resistors(of the same value) if you were to wire all 4 voice coils in parallel, then you would obtain 1 ohm...or, if you were to series all 4 voice coils then you would obtain 16 ohms...a lot of amps are not stable down to two ohms..the way we did it old school was to parallel each speakers voice coils to obtain 2 ohms..and then we would series the 2 speakers in the box to obtain the 4 ohm load needed by the amp
Jan 07, 2011 | Jensen KS-210 Car Subwoofer
I have an alpine cda9831 unit with 10" subs. I have an alpine v power m500 independently running them. The subs will randomly cut off and on and the wires to the head unit have been checked for loose...
so you have already ensured that there are no crossed/loose wire strands.
you are running 2 subs off a single alpine mono amp.
if subs are 4 ohms apiece, you should be fine. if you have 2 ohm subs, or you have dual voice coil subs and you are running all the voice coils parallel, then there is your problem. you can have a maximum of a 2 ohm (2x4 ohm speakers= 2 ohms.) load with that amp.
ensure that the subs are 4 ohms apiece, and that you are not using dual voice coils. if the subs have 2 inputs (dual voice coils) then only use 1 input apiece.
if this is already taken care of, then your amp is defective.
Nov 06, 2010 | Car Audio & Video
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
Try to install 3 12w3d6 subwoofers connecting 3 sub together to put them in box
You need to wire them according to the limitations of your amp you can pull a 1 ohm overall load just by connecting all of your coils in parallel- or you can get an overall load of 4 ohms by wiring each sub individually in a series configuration which will yield a 12 ohm load per sub -and then wire the 3 sets in parallel which will bring your ohms back down to 4. You can do a lot with that many coils it depends on your amp really-ideally a 1 ohm stable class d mono amp that is 1000-1500 watts rms would knock the **** outta those things JL is the good stuff.
Jan 16, 2010 | Jl Audio 12W3 Car Subwoofer
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
Zx-8400 amp too much for zx-4812?
The amp and sub combo should work fine the subs can really take a crapload of power-i have a neighbor thats running 1200 watts rms to each sub in his caddy and OMG- its sick. Your amp should be pushing around 800 watts rms(continous) to the sub which should do very well-my concern with your setup is that the sub is designed for a vented box- you can use any box u want but im just suggesting that you use a good solid vented box with these subs- my other concern with your setup is that having only the single sub if its a dual coil 4ohm + 4ohm coils then you might run into trouble if you dont have it set up right-by that meaning to get all the power handling capability of the sub you would want to use both of the coils right? well to do that you have to either wire the coils in series or wire the coils in parallel right? In series the coils will yield an 8 ohm load to the amp and youll only get about 400 watts from the amp bridged into that 8 ohm load- on the other side of that if you wire the coils in parallel then the cols yield a 2 ohm load and that could cause the amplifier to become unstable and fry its little guts. All of this is assuming that the amp is made to run bridged at 4 ohms- if it is 2 ohm stable in bridged mode than you have nothing to worry about. Now the popping noise- that sounds like its coming from the amp somehow and just feeding through to the sub-like you ive never heard a sub popping unless its bottoming out and you say its not so its gotta be the amp id say-if it were me id check all power connections especially the ground for the amp . It could be that on the heavy bass notes that your amp is not getting enough juice -throw a 3.5 farad capacitor on the power line and see if that helps your system out-
May 22, 2009 | Volfenhag ZX-4812 Car Subwoofer
Help wiring kicker cvr12's
Hello pr7met7me,
Assuming that the "old sony box" has 2 chambers with at least 1 cu/ft of internal volume each, there should be no problem running the Kickers. The CVR's are dual voice coils and come in either 2 ohm or 4 ohm versions. The coils are wired together either in parallel or in series and then wired to the box terminals.
You did not specify what make and model of amp that you intend to use. The amp will dictate how the sub voice coils are wired. You do not want to go below the minimum load that your amp is capable of supporting. If your subs are the 2 ohm version, you wire the dvc's in parallel and then parallel both subs to the amp, your final load to the amp will be 0.5 ohm and there are not many amps stable at that low of an impedance.
The terminals with the white dots are for the first voice coil. The terminals with solid-red and solid-black markings are for the 2nd voice coil. In a parallel setup, you would wire the white-dot positive and the solid-red terminals to the box internal positive and the white dot negative and solid-black to the box internal negative. In a series setup, you would run a jumper from the white dot negative to the solid-red and then connect the remaining terminals to the box terminals.
Hope this helps.
Apr 11, 2009 | Kicker CVR12 Car Subwoofer
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
Jl Audio 13W7 Car Subwoofer Logo
645 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
