Question about Epson Dot Matrix LQ-300+ Printer
Respected Sir, Somebody Has changed printer's original setting but I am facing problem to restore printer's default print setting. There was a sticker on printer's top on that some key combination was given to clearing buffer, font size etc. but it was also teared. Pls give me the key combination for restoring its default print setting. my printer is TVS MSP-245 classic Thanks & Regards
  • Anonymous Mar 27, 2014
    Whenever we are giving a MIS print from an application the print happens but its skipping and printing the next page on the same page. How do we configure the printer so that it recognize the standard page brake in the application and start print in the 2nd page. We have checked on a Laser printer and the page brake of the application working fine there.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 89 Answers
Put a paper in printer
power off
press and hold menu bottn.
power on
a page will print
now change setting whatever you want by pressing LF bottn.and after that press save
power off printer and power on again your printer setting will be cganged as per your requirement
Posted on Jan 09, 2011
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Separator Sheets with smiley faces
Attempt to restore printer to factory defaults to cure this issue.
Sep 06, 2017 | Lexmark T644 Laser Printer
Respected sir i have a printer lbp2900.canon.......the problem is when i command a print, when the print is finish a line appear after the print on the left side of the paper. sir unfortunately one day i...
Do a hard reset of printer to see if that clears up the electronics memory and restores operation. If that procedure and reinstallation of software does not remedy situation then something is wrong with the printer.
Aug 24, 2017 | Canon LASER SHOT LBP-2900 Printer
I have an HP Photosmart C7280 Printer wireless connected. The Pause Printer and Use Printer Offline are always checked on. How do I change the default status on these 2 items to default off. Whenever I...
To change the default printer settings or to restore the settings in your printer, click on the start menu, select Settings, and then select "Printers" from the menu that appears. After that you could right-click the printer that you would like to change settings for, and then select "Properties" from the menu that appears. This would open up a tabbed window that would display many settings that you can change. You could change the settings you need to change or there is another option that you would find to restore to defaults, this would allow you to set the default settings on your printer.
Jan 06, 2011 | HP Photosmart C7280 Printer
Sir i face problem in di 650,i place original
Sir,
Do you have the paper selection in AUTO? Mite you also check your defaults settings
Feb 20, 2010 | Minolta Office Equipment & Supplies
Printer will only print from tray 1 and not tray 2
In your printer properties page you can change the default tray.
Nov 26, 2009 | HP LaserJet 2430dtn Printer
Printer says to re-insert paper face down.
You must have the default printer settings changed to "double-sided" printingor "print on Both sides".
Check in your printer properties: 'Right click' the printer icon. Select "properties", "Printing preferences", "finishing", un-check "print on both sides" (these options vary slightly by printer model, so just check around on the different buttons).
That's my best guess. :)
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Time Out Error
This is from Xante's 3G Manual (downloadable via PDF)
"Printer Timeout The Timeout feature allows you to select the number of seconds the
printer waits for additional data before cancelling a job and returning
to the READY/IDLE state.
Set Timeout from the MISC:TIMEOUT configuration menu. The
factory default of 40 seconds (40 Sec) is an average setting. Set
timeout according to the type of files you send. Use a low setting for
small, simple files to prevent an indefinite tie-up on one job. Use the
300 or Never setting for large files, such as graphic intensive or CAD
(Computer Aided Design) files, to allow enough processing time.
With the NEVER selection, the printer does not timeout; it waits
until it receives additional data or until the printer is reset."
Here is the address where you can download the manual:
http://www.xante.com/support/aw3g/manuals/PDF/complete.pdf
Nov 15, 2008 | Xante Accel-a-Writer Laser Printer
IBM 4232 Printer Problems
in the PRINTER SETUP menu there will be FORMS DEVICE
select and set
Continuous Forms — F1 or F2
Dimensions
Forms Min Max
Width 3in - 15in
Length 3in - 14in
Nov 05, 2008 | IBM 4232 Matrix Printer
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
Epson Dot Matrix LQ-300+ Printer Logo
446 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
