Question about HP Pavilion dv9000z Notebook
Overheats During Extended Use
Unlike many others who have had display issues stemming from the video accelerator running too hot, my dv9000 series notebook will simply stop functioning. The keyboard will become non-responsive, along with the touch pad mouse and any devices that are plugged into the USB ports. Invariably a message will come up saying that there was a delayed write failure (hard drives go offline).
I have also noticed that this machine tends to run very hot, to the point that the keyboard is extremely warm to the touch with no prolonged contact with the areas right below it where the HDD's are housed. Sometimes if I am there when this occurs I can manage to shut the system down by momentarily pressing the power button (have windows power management configured to shut the system down when the power button is pressed for less than 5 seconds).
The display never goes out on it's own or fails to function, and the fans do run at idle with little change in speed as the system warms up or heavier CPU loads are imposed. This machine is never used on the lap (despite it being classified as a 'laptop' or 'notebook'). It is always kept on a hard surface with the rear area propped up (tilted forward) to allow maximum air flow through the vents and fans, no obstructions. This seems to help a little bit, but not much.
HP dv9000 CTO notebook, custom built, Intel Centrino Duo 2.0GHz, 2GB RAM, nVidia GeForce Go7600, DVD-RW, 17" widescreen WXGA display (no brightview), Intel Pro Gigabit LAN w/bluetooth and wireless A,B,G, dual HDD's (120GB/160GB) built March/April 2007 (only available with Vista, 'downgraded' to XP Pro but kept original pre-installed 64 bit Vista Ultimate HDD)
  • Manta69 May 28, 2008
    Yes, both fans do spin freely when the system is off and both do energize when the system is running. The system does get quite warm within an hour after it's turned on, but at this point in time it won't begin to fail until it's been running for several hours (around 8-10). I did purchase the three year warranty at the same time as I ordered the system built, but I am not sure if I have grounds to qualify for a warranty MOBO replacement, considering how long it takes for the system to become unstable.
    Are notebook PC's designed for prolonged use, or should I consider resurrecting my desktop PC?
    Okay, thank you for showing me the error of my ways ;-)
    Champion:
  • 207 Answers
First of all pls do chk weather the fan below the laptop is functioning properly or not do u get lil vibro of the fan ??when u touch it wd ur palm ....it may be due to various reasons how much time does it take to get hot ??if it is too early then sir the mother board is going to say be bye and as u said tht the system become non responsive thts obvious cause the motherboard is malfuntioning tht time if u have the warrenty on the same get the mb replace
Posted on May 28, 2008
  • varun grover May 28, 2008
    8 hr?? thts long please do shut down ur computer after 5-6 hrs for atleast half an hr ...in this case i dont think tht there is some prob yes if the sys fails wd in 30 min or wd in 3 hrs of nonstop wrking then there is some prob wt u are facing is over loading
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
On a 2001 saturn L series, 2.2 litre automatic. gas gauge doesn't work and the temp light blinks continuously while the temp gauge needle jumps continuously. i've checked the coolant levels,th
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 12, 2012 | 2001 Saturn L-Series
Overheat
Car runs hot?
overheating?
Feb 04, 2012 | WELLY 1998 Bmw 328i 3 Series Black 1/18...
Car over heating
For car running hot and overheating issues,i suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems :----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
Jan 18, 2012 | 1991 BMW 5 Series
Engine fails to accelerate and transmission shifts hard in hot weather.On hot days above 85 after the car has run awhile it stops running well. The coolant fan is running seemingly at an excessive speed....
check engine coolant temp sensor, its detect engine overheats that command the computer to engine shutdown for protection, try to replace a good one
Jun 19, 2010 | 2001 Saturn L-Series
HP Pavillion dv9000 - won't power up I have resea...
HP has found some reoccurring issues with some of the HP Pavilion dv9000 series notebook model PCs. HP has extended warranty for 24 months which includes the 1 year standard factory. For more information on “Limited Warranty Service Enhancement Program”, please refer the web link provided below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&tmp_track_link=ot_recdoc/c01611512/en_us/c01087277/loc:1&lc=en&dlc=en&cc=us
NOTE: Clicking the link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
Check out if your notebook is listed in under this program. If yes, then contact HP to get the available options to get your notebook repaired.
May 20, 2010 | HP Pavilion dv9000z Notebook
No display can't boot
Faulty Nvidia Chip
Your Graphics/GPU chip(s) Need to be Reflowed....
Due to Overheating Issues of the Dv9000, the Chips on the motherboard Fail, To Fix This Issue, the 2 chips will need to be "resoldered/reflowed" back to the Motherboard...You should first Check to see If your exact make/model is listed on the HP list of recalls for that dv9000 series... They will repair it at no cost to you as long as you aren't over a year out of your warranty
Nov 15, 2009 | HP Pavilion dv9000z Notebook
Laptop keeps cutting off seems to get hot fast
Hi:
The DV6000 series of notebooks have a problem with motherboard issues, to include WiFi Failure, video problems, and other issues. You can do your own research on this, but it is pretty widespread, to the dv2000, dv6000, and dv9000. Many HP owners were offered enhanced warranties, and at the minimum, received a discount on repair.
See what you can do, as it won't get any better for you.
Nov 10, 2009 | HP Pavilion dv6000z Notebook
There is no display on my HP Pav dv9000
Is there any display during start up? If so, then the possible solution is that the display has been toggled for TV or external monitor display. Try hitting Function F5 on the keyboard (default display toggle function) and see if that turns on your LCD display.
Dec 31, 2008 | HP Pavilion dv9000z Notebook
HP Pavillion dv9000 won't boot up
My 18 month old HP Pavilion dv9803nr Notebook PC will not boot up. It tries to then the light flick off and then on and tries again and again but nothing.
Dec 24, 2007 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
