Question about Samsung SCX4623F Laser All-in-One Printer
What is error code #02-000 on Samsung SCX4623F and how can I fix it?
    Master:
  • Samsung Master
  • 553 Answers
Dear
Its related to the fuser assy. Pl. check the fuser thermostat and heating lamp. for if its open replace it, check the thermistor resistance if it open replace it, Check SMPS.
Thanks.
Posted on Mar 03, 2015
2 Suggested Answers
  • 1116 Answers
SOURCE: I got 02-000 error on
This error is a fuser malfunction. You will need to replace the fuser unit in order to get this running again. A fuser unit will run about $90 for a refurbished unit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 01, 2011
I have a printer scx-4623F error "wait image2" What should I do to fix this error
Dear
This printer has been locked to accept third party firmware or downgrade. You can only check the firmware mentioned at back side cover panel and up date the same or higher.
If firmware fix to reset toner, may be purchased from third party and may be searched from the net.
For the error, make power OFF and ON. It will continue on previous firmware. If not then upgrade to higher version. unless MPBA to be replaced. If the printer has version bellow ,V.xx.xx.99 that are not locked and update freely with third party firmware.
If further information required pl. do comment.
Thanks.
Feb 01, 2015 | Samsung Sas SCX4623F...
Problem with Samsung SCX4623F Mono Laser All in One Copier Scanner and Fax AllInOne Printer showing prepare new cartidge
Dear This means The printer toner cartridge is empty more than 90% [ Less than ten percent toner is remaining].
That is the reason its displaying error. Before it stops We recommend to to bring a new toner. ( do not refill/ or do not use from another printer of the same model.)
All the Best
Rafique
Jun 01, 2012 | Samsung SCX4623F Laser All-in-One Printer
I HAVE SAMSUNG SCX4623F PRINTER I REMOVED & PUT BACK THE TONER ,NOW THE PRINTER IS SAYING " DOOR OPEN , CLOSE IT "
try this:Test if microswitch who tell to printer that front door i closed is working propertly.If you can't test just make By-pass microswitch in your resposibility (because the printer will wor even you open a front door)I have the same error and I sloved in this way.
Sep 08, 2011 | Samsung SCX4623F Laser All-in-One Printer
I got 02-000 error on samsung scx-4623f . How can I fix it?
Jun 01, 2011 | Samsung SCX4623F Laser All-in-One Printer
SAMSUNG SCX4623F PRINTER HAS A LINE DOWN RIGHT HAND SIDE OF PAGE WHEN USING DOCUMENT FEEDER
check the scanner glass (the narrow side), it might be dirty, clean it with a soft cloth and alcohol
May 25, 2011 | Samsung SCX4623F Laser All-in-One Printer
HOLA ME SALE EL ERROR #02-000 EN LA SAMSUNG scx-4623f QUE PUEDO HACER
Nov 12, 2010 | Samsung SCX4623F Laser All-in-One Printer
Cannot find samsung scx4623f drivers
Hi there and welcome to fixya,
What's the model code of your printer? You can download the drivers here:
http://www.samsung.com/us/support/downloads
For a quick link to those files (XAX model)
http://www.samsung.com/us/support/downloads/SCX-4623F/XAX
You only need to select your operating system then start download,
hope this helps.
Nov 04, 2010 | Samsung SCX4623F Laser All-in-One Printer
Samsung SCX4623F Laser All-in-One Printer Logo
2,033 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
