Question about HP Office Equipment & Supplies
I have a hp2180 scanner copier printer. It has stopped printing from the computer. It still copies ok, so doesn't appear to be a cartrdige fault. I have put a new Black cartridge in but still does not print from computer. Have tried a new USB cable from computer to printer. Have tried plugging the cable into the USB port that the mouse was in and that didn't make any difference either. Have checked the print queue, and there is nothing queued. Have turned the printer off and removed power cable, then replaced and turned on. Still nothing. Computer has been turned off over night and still nothing next day.
Posted on Jun 26, 2008
How to put C460FW Samsung printer in "tech Mode"
(From ready to copy/Just finished warming up from power off)
Press the following buttons in order
Menu, Back, Left arrow, Right arrow, OK, Stop/Clear, Menu
Sep 01, 2014 | Samsung Xpress SL-C460FW Laser...
My Epson NX300 prints just fine from anything on the computer screen but, when I try to print a copy from a copy in the printer/scanner tray the paper from the supply rack drops about 4 inches like its...
Connect the scanner to an old USB HUB, and it will work. It stops when you connect to a new USB connection direct in a new PC. Done it. I worked with a 2 port USB HUB. Was posted someplase but I cant remember where. Magnar Vereide Datainstituttet.no
Oct 31, 2013 | Epson Stylus NX300 All-In-One InkJet...
Why is the print blurry
If black & white copies are ok you can probably bet it is an issue with the ITB (transfer belt assy) or a color registration issue. If black & white copies are also blurry.....could be a variety of issues. If it only happens when you copy but printing is ok from the computer......scanner is at fault.
Jul 31, 2012 | Canon imageRUNNER C3200 Copier
Problem with brother mfc 7340 copier: when i copy, two parallel lines appear on copy. thanks for your answer
1. To test, print the Help List:a. Press the REPORTS key located on the control panel.b. Press the up or down arrow key until Help list appears on the display(#2).c. Press Ok. The report should begin printing.Black lines that appear on faxes you send, images you scan into the computer and copies you make are typically caused by dirt or white out on the scanner unit. The scanner unit is the mechanism that reads in the documents that are being copied or transmitted.
Nov 27, 2011 | Office Equipment & Supplies
HP PSC 1210 copier printer scanner wont copy in Black
1. Go to Start>Devices and Printers and click on it.
2. Right-click on your printer and select printing preferences. The printing preferences window will appear.
3. Click on grayscale to put a check in the box.
4. Click Apply.
5. Click OK
Apr 20, 2011 | HP PSC 1210 All-In-One InkJet Printer
On initial setup of my HP5610 the alignment page prints and when I place on the scanner glass and press OK nothing happens.
take out the cartrdiges from the printer and then clean the contact points on the back of the cartridges. then unplug the power cable from the back of the printer and then press and hold down the color copy and cancel button at the same time. and then plug back the power cable back into the printer. try to power on the printer and insert the cartridges one by one into the printer.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When printing multiple pages it prints 1 and & stops & no more
Go to Kodak's site and download and install the firmware upgrade for the printer. Follow all instructions on their site for doing this. There are some printers that have this known issue and apparently is fixed by firmware updates. Also uninstall the printer driver (after successfullly doing the firmware update) and reinstall it. Reboot the computer after reinstalling the printer driver.
Mar 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp psc 1350v WILL NOT COPY OR SCAN
sounds like the scanner/copier engine(same device, by the way) has gone way UnHappy. time for a service call or a recycling effort on that machine..it's a major component..and buried deep inside machine.
Feb 19, 2008 | HP PSC 1350v All-In-One InkJet Printer
204 people viewed this question
Seeker5211
Seeker5211
