Question about Kenmore 60172 Electric Commercial Dryer
My 70 series Kenmore Dryer has a problem with the timer dial so the dryer won't even turn on. It doesn't spin totally freely, but does not make the usual clicking sound when the dial is turned. Will not start at all. It is out of warranty. Better to call a repair person, scrap it, or is it easy to fix? Thank you!
  • lancer4ever Oct 06, 2010
    It seems odd it would be a blown thermal fuse when the timer dial is operating weirdly - such as not making the little clicking sounds as it turns. It there a connection there that would account for this? Are thermal fuses expensive? Do they have to be purchased through Sears or is it a generic part?
    President:
  • 1,554 Answers
The cause of such problem is usually a blown thermal fuse located on the blower housing. It is wired in series with the motor and will result in the dryer not running if it is blown. Disconnect power then remove the rear panel to access and test the continuity of the thermal fuse.
You can bypass the thermal fuse for troubleshooting purposes if you don't have a tool for continuity testing. Tape the thermal fuse wires together or jump a wire between them then insulate them properly. Plug the dryer in then start it. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer runs with the thermal fuse bypassed. Do not use the dryer with the thermal fuse or any other part bypassed due to fire hazards.
Posted on Oct 05, 2010
  • Jahn27
    Jahn27 Oct 06, 2010
    Do the bypass procedure for the thermal as the first step of the troubleshooting to see if it can make the dryer work. Indicate what you have done so far to avoid advising you to do it and expedite the troubleshooting.
    The thermal fuse is a cheap part that costs about $15 or less and it's a generic part. You can purchase it either from Sears, PartsSelect, or RepairClinic. Just enter you model number and look for the thermal fuse under the parts list.
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Kenmore dryer problem
Good day,
Sounds very much like the motor is going bad. Very slim chance that the timer could cause that problem because of pitted contacts, but that would not explain away the noise when trying to start.
Here's a good tutorial if you want to replace the motor.
http://www.applianceaid.com/wpmotor-change.html
Apr 01, 2010 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Kenmore Series 70 Dryer cuts off after a few minutes
The bearings in the motor have probably worn out. Disconnect the motor and take it out of the dryer. See if it turns roughly or not at all by hand. Also try and move the post left to right and up and down and see if there is play in it. It should move very little if at all in those directions and should spin freely if it's good.
Dec 17, 2008 | Kenmore 72982 Gas Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Kenmore Dryer 70 series
Hi, the problem with the dryer not stopping is most likely the switch that controls when it starts. This switch is located behind the button you would push in to start the dryer, and if you can take off the rear panel and get to it, you can most likely adjust the internal contacts so that they don't continuously make contact. Or you could just replace the switch, which might be easier!
Jul 21, 2008 | Kenmore 64742 Electric Dryer
Kenmore 60172 Electric Commercial Dryer Logo
123 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
