I HAVE 2GB PENDREIVE OF TRANSCADE. WHEN WE INSERT IN THE USB PORT. ITS NOT BEING INDICATED IN THE MY COMPUTER. BUT BLUE INDICATION HAPPANED ON THE PANDRIVE. PLEASE SUGGEST ME THE SOLUTION. OR SENT ME THE LINK FOR THAT PARTICULAR PENDRIVE
    Guru:
  • 252 Answers
It is because of the wrong removable media options.you should enable the drive from settings. 1-go to 'manage' by the right of my computer. 2-then go to disk management. 3-you will see your drive name.right click that and enable it or format it.
Posted on Oct 05, 2010
The flash drive no longer operates on the computer, though the light flashes.
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management.Thenright click on Disk 1 removable drive and click Format. After the flash drivehas been formatted it will indicate that it is Healthy.
Jul 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I am not recognising kigston data traveller
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
NOTE Formating the USB flash drive will delete your data.
May 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb storagedevicerepair
Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
Jan 04, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have mistakenly formated my TDK 8GB TRANS-IT FLASHDRIVE and altough it is empty it looks only 9.95MB capacity. Any suggestion to solve this?
Try formatting using Disk manager.
Dec 19, 2009 | TDK (CD-RW74HSFXS5) Storage Media
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
PC is not detecting my Cruzer micro pendrive but
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Nov 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a 2GB scandisk pendrive, I unable to format it, Whenever i tried to format it in command. Msg appered IOCTL call error. how can I format it. Pl help me
Try formatting the flash drive using this method.
Oct 22, 2009 | Transcend (589307) Media
Micro sd 2gb card, not read.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
Oct 17, 2009 | HP Compaq nx6110 PC Laptop
Usb is not responding when inserted into laptop (have tried another computer so fault must be in the flash drive)
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Oct 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When i plug my sandisk 2gb it dosent work!
Have you tried every USB port? Do any other things work on your USB ports? Is it USB 2.0 and your computer only does USB 1.0? Have you tried the sandisk in another computer? Does the USB port feel loose when the sandisk is inserted? Sounds like the sandisk may be bad.
Sep 10, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
David Payne
David Payne
