Question about Xerox Office Equipment & Supplies
Xerox 3030, toner fault. When transporting this machine, toner was spilled and now we get this error message. Any ideas?
    New Friend:
  • 51 Answers
Clean the machine and run toner calibration 9-21-6
Posted on Dec 12, 2010
Xerox 3030 (engineering copier)-- "Toner Fault. Call for assistance" is on the little display screen. Can I easily fix this myself?
I expect you've probably got this fixed by now? In my experience people who own these machines want them working all the time. This error code problem can be over concentrated or under concentrated developer. Possibly needs developer changing, or the DEV sensor could be U/S. Good luck.
Dec 05, 2014 | Xerox Office Equipment & Supplies
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
Xerox DC12 Error code 9-355
Error code 9-355 indicates, the magenta toner dispenser is broken and in need of repair.
Open the Front Door
From left to right, the Toner Cartridge colors are Cyan, Magenta, Yellow, and Black.
As a pre-caution, place a few sheets of paper on the floor, under the Toner Cartridge area, to catch any toner that may spill.
Remove the Toner Cartridge by rotating the handle to the left until the handle is in the unlocked position.
Pull the cartridge completely out of the machine.
Check for any obvious damage in the cartridge or printer and reinstall. Replace cartridge if damaged.
If error message continues, call a qualified repairman.
I hope this helps you fix your printer.
Jan 28, 2011 | Office Equipment & Supplies
Our xerox dc12 gives a message system fault turn power off the swith is on the right side pause and turn back on Code 9-357
The error 9-357 normally refers to a toner issue.
This normally refers to a color/Black toner problem. Probably there is low toner sensor defect.
Check for the ink in the cartridges as well but before that try to vacuum and clean the toner dispenser. You must vacuum whole path which is used to transport the toner to developer unit.
Feb 28, 2010 | Xerox DocuColor 12 Color Copier
I require a service manual for a xerox 3030 wide format photocopier so I can learn to install a new toner
Fuji-Xerox XP-11 (Xerox 3030) Toner / OPC
6R281/13R32, 20k Under switched off printer press and keep the button of the unset, residing near by cord of the feeding; include the printer.
Procedure alike for both cartridges
Sep 02, 2009 | Xerox Office Equipment & Supplies
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
Phaser 8560DN Printer ~ Error Message
An error code due to the print head, check the waste tray area for a spill, has the printer been moved lately? remove left cover and look for spill.
-Carl, please let me know if this helps.
Jun 25, 2009 | Xerox Phaser 8560DN Printer
J3 error On Xerox WorkCentre Pro - 215
A J3 means the toner cartridge is not compatible. That is the what the J3 message means.
Make sure the correct cartridge has been installed. For example, a Pro16 Toner Cartridge looks very similar and will fit in the machine, but it will display a J3 fault. Install a known correct Toner Cartridge if you suspect the cartridge in the machine is the problem. If the wrong Toner Cartridge has been used, the correct cartridge needs to be ordered and installed in the machine
It is possible the chip on the back of the cartridge is bad. Have you tried reseating the cartridge? Maybe it is just loose.
Dec 19, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Xerox docucolor system fault problem
hi please chek and tell what error code showes in your display.. some error codes showing in ur display, pls check it that.
Aug 25, 2008 | Xerox DocuColor 12 Printer
That is a magenta toner empty message, either the magenta is empty of there is an issue with the magenta toner dispencing.
May 07, 2008 | Xerox DocuColor 12 Color Copier
508 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
