Question about Acer Aspire 5500 5570-2609 Laptop
Keyboard is not working properly
I'm running this laptop with vista. Some of the keys do not work. I made sure there was no dust or any other object in the way, I've checked to make sure the drivers were up today. On occassion, the keyboard will work properly but more often than not the "n" "." "," won't work unless i use the cap lock.
I can type the letter in uppercase, then delete it, hold down the shift key again and will get lower case. But, I have to go thru this exercise every time i want to use a key that doesn't work properly.
Any advice?
    Champion:
  • 207 Answers
Two cases
either the keypad is getting non responsive either the wind are not picking up the drivers if u dont have much data try running recover and c result will be there
Posted on May 28, 2008
Keyboard on Inspiron Mini 10 is not working right. Had chocolate spilled on it. How do I clean it.
Because laptops are portable, people tend to eat and drink over them. They lay the laptops on soiled surfaces and stuff them in dirty book bags. With all of the wear, tear and abuse that a laptop sustains, it's no wonder that the keyboard can become quite dirty. When a keyboard becomes dirty, often times the actual keys won't work. It is commonplace to find dirt, debris and food under the keys of a laptop computer. This causes the keys to not engage properly, rendering them useless.
1.Run a duster over the keys of your Dell laptop. This will remove any dust or small bits of debris that are causing your laptop keys to get stuck and not work. Test your keys once you have dusted them.
2.Spray the laptop keyboard with condensed air. Hold the air nozzle (you will often insert a small plastic tube into the nozzle) about 4 inches from the keyboard. Spray liberally, and use a back-and-forth motion while you work. This will remove most pieces of debris that may be stuck under the keys. Test the keys to see if they now work.
3.Place the tip of your flat-head screwdriver underneath the right-hand side of the key that is not working. Lift up gently and the key will pop off.
4.Dip the tip of your Q-tip into the rubbing alcohol and rub around the area where the key meets the keyboard. This will remove any final bits of dirt and debris. Allow the area to air dry. Repeat on as many keys as needed.
5.Place the loose key directly over the space where it belongs. Note the small piece of rubber. Hold the center of the key directly above the rubber piece and press down. When you hear a small clicking sound, the key is secure.
Sep 09, 2011 | Dell Inspiron Mini 10 Notebook
I have a problem regarding my lg x110 notebook. some keys are not working properly like the letter g on the keyboard, when i hit the letter g it appears letter c on the monitor same as letter t and z and...
Examine your keyboard for any build-up of dust, dirt, liquids or other particles that could be causing the keys to type the wrong characters. Allow any loose dirt to fall out by inverting and shaking the keyboard lightly.
Confirm that your keyboard is set to the English language. Go to your control panel and click on the "Regional and Language Options" icon. If the setting appears to be in a foreign language, change it to English/U.S.
Check if your number lock key is on. If so, depress the key to disengage it.
Run a character key test by using the Microsoft Keyboard Diagnostics (MSKEY) program. While in the MSKEY program, hit several keys to make certain that they are the same keys that are identified in the MSKEY window. To start MSKEY in Windows Vista, select "All Programs>>Accessories>>Run" from the Start menu. Type "mskey" in the box and depress the "OK" button. Start MSKEY In Windows XP by clicking on "Run" from the Start menu. Type "mskey" in the Open box, then hit "OK." Depress either "PS/2" or "USB" to apply it to your type of keyboard hookup. MSKEY software is only available with Microsoft IntelliType version 1.1 or later.
Remember to clean your keyboard regularly to keep it free of dust and debris.
Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty!
May 08, 2011 | LG Computers & Internet
How to re set key board with HP Pallion laptop, some of the keys are not working correct
Hello, The cause of keyboard not properly functioning is dust, if you can open your keyboard and blow out the dust using compressed air or pc vacuum blower .If this does not work then you need to change your keyboard,better still you can get an external usb keyboard and use, it will work. OR GOTO START>ACCESSORIES>EASE OF ACCESS>ON SCREEN KEYBOARD Regards
Dec 09, 2010 | Computers & Internet
Hi the "F" keys on
Hi Friend, In this case I would recommend you to please try and connect any external keyboard to the laptop and check if the "F" key works from the external one
If it works it means that there is a need to replace the keyboard of the system If it still doesn't work then it means that there is a need to update the drivers for the system
NOTE: Please make sure that some dust is not stuck in the under the key
Dec 09, 2010 | HP Compaq nx6110 Notebook
Laptop Keybord is not working properly. If we click on one letter it is showing another letter.
Download and run Ccleaner here:
Run cleaner and registry cleaner. then:
Plug your keyboard into another computer. If the keyboard works, then the port on your original computer may not be working.
5
Tips & Warnings
Clean your keyboard regularly to keep it free of dust and debris.
Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty.
Good luck. If this helps please consider giving me a good review.
Thank you and good luck
Oct 19, 2010 | Acer Computers & Internet
My key board isn't working properly when you type anything on the bottome roll it types extra characters
Good day sir/maam. Hi, chances are that the keyboard part is dirty, dust and dirt do find there way inside. You may need to dissassemble the laptop and clean the contacts of your keyboard and visually check the unit. well to be safe bring it to your dealer and inquire about your laptop problem.
Aug 06, 2009 | Computers & Internet
Switched keys
Hello there:
you have got dirt or dust under the key. get some canned air and turn off the laptop and blow out the keys really good. than restart the laptop and you should be fine
Jul 22, 2009 | HP 386209-001 Keyboard
Compaq laptop keyboard mulfunction
try having your laptop checked by a competent technician... there might be an obstruction in your keyboard (like dust) which causes the key to stuck and have it cleaned
Aug 09, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
I didnt understand the solution for the router not working on vista
Try hitting <Fn> + <F2> keys on keyboard. If that doesn;t work click Start > Run > type devmgmt.msc > check device manager for your wireless adapter properties --- is it working properly?
Jun 26, 2008 | Dell TrueMobile 1184 Wireless Broadband...
Acer Aspire 5500 5570-2609 Laptop Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
