Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Spots on freezer door
We have hard water in our water/ice dispenser and we have streaks/spots on the freezer door under the dispenser that we cannot remove with stainless steel cleaner. Any suggestions on how to remove these would be appreciated!
  • 828 Answers
Use a product like lime-away may help. These water spots are caused from calcium buildup. Lime-away or similar product will dissolve the calcium. Then use the stainless cleaner on it.
Posted on May 31, 2008
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Model GSS25TSRE SS Water dispenser does NOT work, but the ice dispenser does dispense ice. Looks like the freezer compressor is NOT working. Help!
Most likely you main control board is bad.... Replace it and your troubles will go away... It is located inside back panel of fridge on the right hand side if you are looking at the back. Sometimes if you unplug power and remove board you can see burnt spots on the back of it but not always.
Nov 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our LG fridge had an issue where the water supply was cut off, so the ice cube maker stopped working as well as the water dispenser in the front. The water valve was replaced, and the ice maker started...
it could be a frozen water tank inside freezer door. if so, door will need to be replaced; as, there was maybe a spot where the foam inside door wasn't sprayed properly. disconnect water line fitting under door behind kick plate; close door and try dispenser. this will verify if it's the door or not.
Sep 22, 2010 | LG LSC26905TT Side by Side Refrigerator
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
I have a Jenn-aire JSD2695KES - it is a side by side, a couple of years old with an ice maker. Ice gets jammed in the last ice spot in my ice maker. It has been getting stuck in other spots lately, too,...
That sounds like a frozen over water fill tube due to a leaking water control valve. You may need to pull the ice maker out to see it but what you described is what happens when this happens. If frozen over the water will still come out on some models because there is a split in the top of the fill tube. Or something needs corrected on the amount of water time is OK for your ice maker. let me see if I can find the service manual for your model Be back soon Sea Breeze
Sep 21, 2009 | Refrigerators
Water drips on floor under the door.
Take off the lower part on the back. Follow the water line up the back. It is connected in two spots lowere rear and upper rear going into freezer.
Feb 08, 2009 | Kenmore 44103 Side by Side Refrigerator
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Water dispenser does not work
the problem is in the freezer door insulation, or lack of, get your model number and serial number handy call 800-386-1215 and see if your machine is under the door replacement program
Worth the try
Apr 10, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Rust under water dispenser on freezer door
Yes it is very hard to do. Its a bit easier with two people but still a pain in the but! goodluck....
Dec 17, 2007 | Frigidaire FRS23R4A Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
209 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
